Author Topic: Startup / Shutdown with Mame  (Read 1062 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
« on: August 02, 2004, 06:45:21 pm »
Quickie ..
Using Mamewah, can you boot / shut down without seeing the windows splash / shutdown.
Also, if so, how do you disable scandisk from starting on boot.
Lastly, is it easier to do in dos? (Should I be thinking of dos version of Mame .. and ArcadeOs if I want to do this?)
Thx :)
TJ
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
Re:Startup / Shutdown with Mame
« Reply #1 on: August 03, 2004, 06:32:43 am »
Um, well it doesn't have much to do with MAMEWAH...
If you can do it to Windows, then all you need do is place MAMEWAH in Startup or use it as your Windows shell.
There have been LOADS of topics about this on this board, try a search (not being unhelpful, but I can't remember it all)...
Edit: I would only use DOS if you have a really old PC...like <~500MHz.
« Last Edit: August 03, 2004, 06:33:39 am by Minwah »
Halo
  • I'm a lamer!
« Reply #2 on: August 03, 2004, 03:31:05 pm »
Cool ... searching now, thanks for the reply :)
