Author Topic: Cleaning surface after painting/sanding  (Read 1750 times)
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« on: August 02, 2004, 01:33:46 pm »
OK, before priming, and after sanding in between coats, how do I clean the surface? Shopvac, towel? Some is MDF so I don't want to wipe with any kind of liquid...
Thanx!
BYOAC users get 5% off with coupon code byoac5
Heartburn
  • Last login:August 05, 2004, 04:41:26 pm
Re:Cleaning surface after painting/sanding
« Reply #1 on: August 02, 2004, 01:41:21 pm »
Tackcloth might work.  It's a sticky (but not moist) rag used just for this sort of thing.  It should be easy to find.
greywolf22
  • Last login:January 01, 2020, 12:45:06 am
  • My cab is always a work in progress
« Reply #2 on: August 02, 2004, 06:22:13 pm »
Yup I used a few tackcloths and it worked like a charm.  I was able to find it with the painting supplies at my local ACE hardware.  Very sticky and works great
rdagger
« Reply #3 on: August 02, 2004, 09:37:41 pm »
Compressed air works well.  If you are using a sprayer, you can disconnect the hose from the gun and blast the surface with air.
