Author Topic: Wiring an ATX power switch to a button  (Read 2752 times)
TOK
  • The Game Always Wins
« on: July 31, 2004, 08:23:28 pm »
Are the power switches on ATX cases the same type of "Normally Off" switches we use for cabinet buttons?
I was thinking about extending the lines from my PC's power switch and just using an out-of-the-way standard button to power it on. Powering it back down isn't an issue, since I'm using XP and can shut down through Windows after a session.
Sorry if this has been covered already. I looked around a bit and didn't find info.
Tim
crashwg
Re:Wiring an ATX power switch to a button
« Reply #1 on: July 31, 2004, 08:30:21 pm »
Yes.  You are 100% correct, this will work, and has been discussed before.  But I'll let it slide... This time  >:(
J/K
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
TOK
« Reply #2 on: July 31, 2004, 08:34:21 pm »
J/K
Three whole minutes for that answer. What took ya so long?
Thanks a bunch!  ;D
MonitorGuru
« Reply #3 on: July 31, 2004, 09:51:05 pm »
same thing goes for reset buttons.
mattv
  • Last login:June 10, 2022, 06:33:25 am
« Reply #4 on: August 01, 2004, 02:08:06 am »
Crashwg has said it all
An ATX power switch is a standard normally open momentary switch. You close the circut once and it goes on, you close it again and it goes off.
So any standard arcade button will fill this role just fine.
On a totaly unrelated note, the fact that the ATX power button is a "stateless" momentary switch means that there is power running through your PC regardless of if it is on or off. for this reason it is not always a great idea to swap AGP video cards unless your machine is off at the wall.
Also, on some older keyboards this results in the caps/number/scroll lock LED's still working when the machine is off. Not 100% sure if that little gem will be useful to anyone, but it's too good to keep to myself.
Demon-Seed
    • DemonCade (WORKING URL!)
« Reply #5 on: August 01, 2004, 11:44:53 pm »
Here is a great link to learn how to do it.
http://joelsgadgets.com/computeronpushbutton.html
I did it works great!
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
« Reply #6 on: August 02, 2004, 09:11:43 am »
what about hacking a light switch? i'm thinking about doing this for my cab, but am still "researching" it.
