Author Topic: Anything to look out for when upgrading from Mame 0.82 to 0.84?  (Read 1365 times)
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
I'm thinking of upgrading from MAME 0.82 to 0.84 in the hopes it will take care of some sound issues I'm having.  I'm hesitant because I don't want to lose any speed and my romset is for 0.82.  I read something about the ctrlr files being absent in some builds of MAME0.84 but I'm not using any of those so I don't think that should affect me.
I'm planning on simply swapping the exe files.  Should there be any problems with this?
-G
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
SirPeale
  • Green Mountain Man
Re:Anything to look out for when upgrading from Mame 0.82 to 0.84?
« Reply #1 on: July 28, 2004, 03:34:10 pm »
So just rename your old mame.exe to mame.bak and put the new exe in.  Unhappy?  delete the new and rename the old.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #2 on: July 28, 2004, 04:03:20 pm »
well, theres those pesky monkeys, and the tornado's will get you...but other than that, that's all you have to watch out for.  oh, and ugly chicks, watch out for that too.
« Last Edit: July 28, 2004, 04:04:01 pm by hulkster »
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #3 on: July 28, 2004, 04:07:23 pm »
They did take -listinfo out of MAME, so the current build of mamewah and some other tools need small workarounds to work properly.
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« Reply #4 on: July 28, 2004, 04:07:40 pm »
Also if your front-end used --listinfo to get information instead of --listxml, you may have issues with 0.84... which only allows --listxml.
But hey, easy to find out, just do as directed above and keep your old executable around.
-->VPutz
« Reply #5 on: July 29, 2004, 06:48:51 am »
Loads of input stuff has been changed / broken in MAME v0.84, so personally I wouldn't upgrade yet.  u1-5 fixes many things, but also breaks others.
I wish I hadn't moved from 0.83 to 0.84 to some extent, and I would recommend you wait until 0.85 at least...
simplygriff
    • simplygriff.com
« Reply #6 on: July 29, 2004, 12:29:14 pm »
Thanks for all the input fellas...
I did upgrade last night and as peale said I kept my 0.82.exe.  I'll probably go back to it too.  0.84 didn't fix my sound problem.  I have another thread devoted to the sound thing.  I'll post there.  THanks again.
Edit:  Link to other thread.  http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=22213
-G
« Last Edit: July 29, 2004, 12:33:29 pm by simplygriff »
www.simplygriff.com
