Author Topic: Mamewah and Zsnesw  (Read 1174 times)
Evilpenguin
  • Last login:November 30, 2007, 06:53:35 pm
  • MegaMame
Mamewah and Zsnesw
« on: July 27, 2004, 05:20:26 pm »
How do you get mamewah to just load the rom.  When I click on a rom it just brings up the interface of Zsnes?  Any ideas?
Jason
TalkingOctopus
    • My Arcade
Re:Mamewah and Zsnesw
« Reply #1 on: July 27, 2004, 05:43:24 pm »
Makes sure you are using the following settings in the MAMEWAH emu#.cfg for zSnes:
Show DOSBox = 1
Send ROM Path = true
Use Long Filenames = false
Send ROM Extension = true
« Last Edit: July 27, 2004, 05:45:49 pm by TalkingOctopus »
Evilpenguin
  • MegaMame
« Reply #2 on: July 27, 2004, 06:36:14 pm »
Thats exactly what I have.  The roms show up in mamewah and when I click on one of them to load it just brings up the gui for ZSNES, any ideas, I suppose I could use the controls to select load and then select a rom, but I should not have to I would think.
Jason
TalkingOctopus
    • My Arcade
« Reply #3 on: July 27, 2004, 07:29:22 pm »
Try the version of zSnes that you can download from the screenshot archive:  http://www.screenshotarchive.com/downloads_emus.htm
« Reply #4 on: July 27, 2004, 08:02:16 pm »
Try using Long Filenames...
It has been a while since I had ZSNES setup so I can't remember fully, but I know for sure it works.  The GUI appearing is basically telling you something is wrong with the rom part of the commandline.
If all else fails run ZSNES from a commandline until you figure out how to run it, then try to duplicate that in MW (use debug.log to help).
