Author Topic: Buttons input problem  (Read 833 times)
Gradius
  • Last login:February 04, 2008, 03:10:49 pm
« on: July 26, 2004, 05:28:42 am »
I've noticed a problem with one of my controls panels. It's a psx pad hack, using a usb adapter under win98. Sometimes, one of the buttons register input, even when it's not being pressed, and even if I remove the microswitch. I think this happens with 2 of the 6 buttons. It happens now and then, and I notice this specially when I remap the special button in shoot'em ups to one of these buttons. I'm playing normally and ocasionally the bomb or the special attack is executed. I couldn't be sure 100% but I think this happens only with MAME. I've been testing it for a while in the control panel window and these buttons don't seem to input if you don't press them. Could it be a problem with MAME? What test could I carry out so as to isolate the problem and find out the cause of it?
reebboy
  • Last login:December 12, 2005, 01:34:53 am
  • Now its time for some serious insanity!!!
Re:Buttons input problem
« Reply #1 on: July 26, 2004, 07:39:43 pm »
Have you checked your default MAME key settings and make sure that the key you have assigned to the problem button is not also assigned to something else. I had a similar problem and found this to be the cause.
I had the letter "T" assigned to something like the second player RH joystick button. I couldn't figure why everytime I went to the right the game would do starange things. I found that by default MAME assigns the "T" button to the "TILT" function. So everytime I moved the joystick right I went right and tilted the game at the same time.
Dude!!! Where's my game.....
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #2 on: July 27, 2004, 05:37:21 pm »
it could also be due to the fact that you are using a psx pad hack.  when i built the lpt port interface, i had to tweak the scan/clock settings in the drivers to get it to work correctly.  if it was just a little off, i would sometimes get a particular button registering a keypress..
Gradius
« Reply #3 on: July 28, 2004, 02:14:35 am »
But I'm not using lpt, but USB adapter under win98...
Bgnome
  • Who's da gnome?
« Reply #4 on: July 28, 2004, 12:02:07 pm »
im just saying that it could be a scan/clock issue, regardless of the interface.  different settings are optimal for different controllers.  have you tried using different controllers on your adapter?
