Author Topic: ( Vertical ) width coil.  (Read 1725 times)
Meet and Greet
  • Last login:July 24, 2004, 11:57:20 am
« on: July 24, 2004, 07:37:02 am »
The width coil allows for additional horizontal adjustment over the regular pots. But is there a width coil for picture height or vertical screen position?
Monitor is WG 7000 series.
Jomac
  • Last login:October 16, 2024, 03:11:19 pm
  • CapKit vs Shotgun = same result !
    • Jomac
Re:( Vertical ) width coil.
« Reply #1 on: July 24, 2004, 08:05:27 am »
No , just the normal pots .
Meet and Greet
« Reply #2 on: July 24, 2004, 11:59:00 am »
Oh well, thanks :( for the bad news.
MonitorGuru
« Reply #3 on: July 24, 2004, 07:10:23 pm »
Width is adjusted by adjusting frequency, therefore horizontal is always a coil wrapped around a ferrite (iron) core.  All the other adjustments like vertical, brightness/contrast/color are just change in voltage, therefore they only need to be variable resistors (potentiometers/"pots").
That said, most monitors have pots.  However some models like the K4600 WG actually don't have pots but a few fixed positions with a couple resistors. I have never owned a K7000, but look for a wire soldered onto the board and then reattaching to the board in a row of 3 or 4 silver posts.  These should adjust width and position of vertical, at least they do on the 4600 series.
Jomac
    • Jomac
« Reply #4 on: July 24, 2004, 11:36:40 pm »
monitorguru , there are no extra adjustments or jumpers on the 7000 , just vert pos and vert size pots .
If you want one to play around with I have heaps of these spare and would be happy to pass one on , just let me know.
