Author Topic: Post all BYOAC, MAME, .984", & 25mm Token Mech modification hints in here.  (Read 82873 times)
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
OK, I thought it would be a good idea to have a single place for people to find information about adjusting their mechs for the .984" (25mm) BYOAC tokens.  (Really any .984" tokens.)
I was easily able to adjust my metal "Coin Controls" mechs for the tokens.  It took two steps.
1) I adjusted the white plastic screw to allow the mech to accept a token slightly larger than a quarter.  I had to turn it about 5 degrees clockwise if I recall. (thanks to Quarterback for the better pics)
2) I am not sure if this is necessary for everyone, but I had to fiddle with a second adjustment at the bottom in order to get the mechs to take both quarters and tokens.  I think this is a step that checks the weight of the coin, but I am not sure.  It took me a good 30 minutes to get both of my mechs just right.  It is just trial and error.
At the end of the day, about one of every 25 tokens/quarters doesn't pass.  This is close enough fo me.
Dave
« Last Edit: February 20, 2010, 11:30:00 am by Santoro »
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
Re:Post all BYOAC (.984") Token Mech hints in here.
« Reply #1 on: July 23, 2004, 10:40:46 am »
1) contact TheNasty and buy his all in one mech.  it accepts pennies, nickels, dimes, quarters, tokens, and just about anything else that is close to those sizes.  i think he said it took washers too but dont tell your friends that!  i bought one, and replaced the mechs that came with my happ coin door, and it works great.
Stingray
« Reply #2 on: July 23, 2004, 11:28:28 am »
If you have a Bally-Midway coin door that was originally set up for quarters you might want to be aware that the BYOAC tokens won't fit through the slot, they're just a tiny bit too large in diameter. This is something that can be fixed with a dremel and a little patience, but I just though folks might want to be aware of it. The chrome coin slots can be removed from the inside. It's easiest to take them off and work from the back side in case you slip with the dremel you won't scratch the side that shows.
-S
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #3 on: July 23, 2004, 01:43:22 pm »
Happs IL quarter coin mech adjustment.
http://www.miavio.com/HappILMech.htm
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #4 on: July 23, 2004, 09:35:39 pm »
I am using a pair of the Imonex $.25, .882 & .900" Token Coin Mech (#42-6901-00) from Happ Controls.  I bought them quite a few years ago (back when they were $15 each).  The only modification I have done to them was to loosen and move the triangle piece that is where the coin enters the mech.  This piece of plastic limits the size of the coin that the mech will accept.  I did this quite a while back to make them accept a Chuck E. Cheese token I had.  These don't accept coins smaller than what they are supposed to but do accept coins that are bigger (with the adjustment). Below is a picture of the back of the mech:
Alucard90
  • Last login:June 26, 2011, 05:57:10 pm
« Reply #5 on: July 23, 2004, 09:42:11 pm »
My friend's father is the president of imonex! Ill ask him! im not lying! i do!  ;)
« Last Edit: July 23, 2004, 09:54:28 pm by Alucard90 »
crashwg
« Reply #6 on: May 08, 2005, 04:07:13 am »
Washers are worth more than pennies for the most part...  I'd rather get a few of them than pennies, at least washers are usefull!
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
Re: Post all BYOAC & MAME (.984") Token Mech hints in here.
« Reply #7 on: May 08, 2005, 10:37:19 am »
I've got the tan plastic type (coin controls I think). I don't know how you'd go about modding them for tokens, but I'm sure there's a way to do it, right?
Until I figure that out, I could always just have a cup full of quarters on the shelf next to my cab. But then there's the possibility that my friends might "accientally" walk off with them, and Tokens would definately solve that problem. I'd probably want to change the reject button stickers if I switched to tokens though.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #8 on: May 08, 2005, 04:12:59 pm »
Folks are probably more likely to "accidentally" hork your tokens than plain old quarters!
Timstuff
  • I feel asleep !!
« Reply #9 on: May 09, 2005, 11:21:04 pm »
lol ;D
I suppose the best thing to do would be to order a sampler pack and toy around with my mechs until I can get them to accept the tokens, but it'd be nice if I knew exactly what I was doing. And I'll probably want to replace the stickers on the reject buttons to say "Tokens" instead of "50 cents", but I'm not sure what the best way to go about that would be.
gotstik
  • Last login:November 19, 2005, 11:38:05 pm
« Reply #10 on: May 10, 2005, 09:56:28 pm »
Anyone have any new successes modding your mechs to accept .984" tokens?
Hey Dave _ While I wait for my tokens ;) using an old chipmunk vending token to realign the slots on my mechs.. I have 3 that have adjusted perfectly for quarters and .984 tokens! The other 3, I am struggling with that secondary adjustment..
Kremmit
  • - AHOTW -
« Reply #11 on: May 10, 2005, 10:22:20 pm »
lol ;D
They're the same size as Chuck E. Rat tokens, if you want to test with those.
aumameman
  • Last login:November 18, 2009, 09:50:07 pm
  • AUSSIE MAMER !!
    • Arcade joystick - First attempt
« Reply #12 on: July 03, 2005, 10:49:26 pm »
Hey all,
Just a random thought, another option is to get one of those electronic coin mechs that check a sample coin (or token) against the coin being inserted and accepts or rejects accordly. I have one and they work great.
« Last Edit: July 03, 2005, 10:52:31 pm by aumameman »
-- The Internet has you --
Q*Bert_OP
  • Oh yes, we did!
« Reply #13 on: July 04, 2005, 12:41:38 am »
Make this a "Sticky topic"...
quarterback
« Reply #14 on: August 25, 2005, 11:30:01 pm »
I just adjusted my Coin Controls mechs to accept quarters and two sizes of tokens and I will have comments shortly
But first, here are some clearer pics of what Santoro orignally posted in this thread.
-- Chad Tower
quarterback
« Reply #15 on: August 26, 2005, 12:48:23 am »
Okay, first off I want to thank Santoro for posting this thread.
« Last Edit: August 26, 2005, 01:10:26 am by quarterback »
-- Chad Tower
KonkeyKong
  • Last login:October 10, 2021, 09:57:07 pm
  • Monkey is my business and business is good.
« Reply #16 on: September 20, 2005, 09:34:35 am »
Has anyone modified one of the older tan coinmechs (the ones that say wash in hot soapy water on them) to accept tokens?
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #17 on: September 20, 2005, 10:24:50 am »
Hey all,
I really like this idea...where do you get these?
quarterback
« Reply #18 on: September 20, 2005, 11:28:12 am »
A Google of "electronic coin selector" (from the front of the boxes) turned up a number of hits, including:
http://www.coinopexpress.com/products/parts/cash_handling/Anti-String_Electronic_Coin_Selector_5723.html
-- Chad Tower
MustardTent
    • Blog
« Reply #19 on: September 20, 2005, 12:31:20 pm »
Well, I was going to reply with some smug "I know how to google" comment, but then I realized that the link you point to (one that I did visit) is what I want.
D'oh.
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« Reply #20 on: September 20, 2005, 06:47:30 pm »
The link shows minimum order : 21.
Guess you need to pick up a carton.
Teamwork - A group of people running around doing what I say.
aumameman
  • AUSSIE MAMER !!
« Reply #21 on: September 29, 2005, 06:55:30 am »
ebay was my source. ultimarc.com the maker of the ipaq have then on their website for sale as well as coin doors that you can use with these mechs (i dont know why you'd bother..see ultimarc.com)
Hey all,
« Last Edit: September 29, 2005, 07:02:18 am by aumameman »
holdennut
  • Last login:January 16, 2015, 04:53:06 am
  • Aussie lowboy cab finished!
    • Australian Cocktail Pac-Man Project
Re:Post all BYOAC & MAME (.984") Token Mech hints in here.
« Reply #22 on: January 31, 2006, 08:35:29 am »
Has anyone  modded a Happ Ultimech $.25 Coin Mech to accept .984" tokens yet?
One of these: http://www.happcontrols.com/coindoors/42307900.htm
Cheers
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #23 on: January 31, 2006, 09:25:13 am »
It was done and linked-to above in MP2526's post but unfortunately the link is dead now.  If anyone happened to save that it would be cool if it could be posted here.
The text is here: http://web.archive.org/web/20050212035946/http://www.miavio.com/HappILMech.htm
but the photos are gone.
« Last Edit: January 31, 2006, 09:26:58 am by Santoro »
holdennut
« Reply #24 on: January 31, 2006, 07:40:37 pm »
Thanks Santoro, if anyone has the photo's that would be awesome.
holdennut
« Reply #25 on: February 02, 2006, 06:06:03 pm »
Hey guys, found a quick fix that should work for the Happs IL coin mechs
First remove the little black cir-clip holding the "Red L-Shaped Leaver" in place. The lever should now come off. You should now find that the BYOAC tokens work a treat.
I can't verify this as I don't have any BYOAC tokens, but mine now accepts quarters, aussie half penny and 2 francs. All very close to the BYOAC tokens.
Hope this helps
Before...
After...
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #26 on: February 02, 2006, 06:27:58 pm »
Here are the instructions for these mechs from the original site.  Big thanks to Mike Perry (MP2526) for this - he was cool enough to go and retake the photographs for us!!
Thanks Mike.
Modifying Happ Quarter Mechs for .984" Token Use
« Last Edit: April 02, 2007, 02:59:52 pm by Santoro »
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #27 on: February 03, 2006, 09:30:48 am »
Quarterback,  somehow I missed the fact that you re-took my pics until now.  Awesome, thanks.  I am going to replace the ones up top with these.
Mind if I use them on my website too?
edit: Fixed dumb mistake  :)
« Last Edit: February 03, 2006, 12:39:50 pm by Santoro »
quarterback
« Reply #28 on: February 03, 2006, 12:00:16 pm »
LOL,  I am *a* metalhead, but I'm not *the* Metalhead :)
But, beyond the mistaken identity, sure.  You should absolutely use those pics wherever & however you like.    I took them for that purpose, but thanks for asking anyway.
Cheers
Metalhead, somehow I missed the fact that you re-took my pics until now.  Awesome, thanks.  I am going to replace the ones up top with these.
-- Chad Tower
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #29 on: February 03, 2006, 12:18:15 pm »
*Blush*  Sorry - the Avatar threw me.   It's also widely known that I am scatterbrained..  Oh well.
Thanks though, I am not sure how I missed those before.
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #30 on: April 03, 2006, 12:15:21 pm »
aumameman has successfully modified his Bally/Midway coin slots to accept .984" tokens.
>> http://forum.arcadecontrols.com/index.php?topic=52277
stan2323
  • Last login:September 06, 2026, 01:34:17 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« Reply #31 on: January 23, 2008, 05:55:43 pm »
Someone mentioned tan plastic below.  I have tan plastic coin mech and I had no problem moding it to take tokens.
First squeeze the 2 pins that the arrows are pointing at in the first picture to open the side of the mechanism.
Then remove the E clip on the end of where the arrow is pointing in the 2nd picture.  It has already been removed in the picture.  Then take off the piece that it holds in place.  You will not need that.  I think what that does is not let a coin that is the wrong weight go through.  It acts as some kind of weighted trip lever.  I do not know for sure.
3rd file the lip where the arrow in the 3rd picture is pointing to let a token pass.  The 4th is a close up of the completed filing job.  Once a token passes through shut it and test.
The last picture is the other side.  It was next to the game counter so I could only open it a small amount but I was still able to remove the pieces and file it down to take tokens.
It took 10 minutes to do with a Leatherman to pull of the clip and the file on the Leatherman to do the filing.
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #32 on: January 23, 2008, 08:14:59 pm »
Thanks for those instructions. I'm pretty sure that's what mine looks like (stock mechanism from a centipede cab). So with your mod, does it allow both quarters and tokens? It sounds like you are basically disabling the limiter (or whatever it's called) so it won't reject non-quarters, thus causing it to accept anything that will fit through the slot. Is that true?
stan2323
    • My home page
« Reply #33 on: January 24, 2008, 09:47:28 am »
Mine will not take pennies, dimes, nickels, 1 Euro coin, 2 Euro Coin, 50 Euro cent coin, or Syracuse bus tokens. It still rejects too small items and too thick items.
It did take Quarters, Chucky Cheese Tokens, and some other generic tokens I have with my slot machine.
shardian
« Reply #34 on: January 24, 2008, 10:44:34 am »
That is a sweet guide for modding plastic mechs! I will be trying that out some time soon. I have 5-10 "broken" plastic ones, and this might bring them back to life as a token mech. ;D
shardian
« Reply #35 on: February 02, 2008, 10:25:34 am »
Once again, I'll say you rule for the plastic mech mod! I had 5 that wouldn't even accept quarters that I was going to trash. Pulling off that locking piece allowed quarters to work again. The sanding didn't quite work though. After inspection, I noticed that the ChuckECheese tokens were hitting the hinge of the coin reject. I sanded the round part down a bit and they work flawlessly.
In closing,  :notworthy: :notworthy: :notworthy:
stan2323
    • My home page
« Reply #36 on: February 02, 2008, 05:44:17 pm »
Congrats.  Glad it helped.
NIVO
« Reply #37 on: February 02, 2008, 07:53:00 pm »
gonna go ahead and sticky this for now. Good useful info here as usual  :cheers: May be moved down the road to another area, keep your eyes open for redirect links.
TheShanMan
Re: Post all BYOAC & MAME (.984") Token Mech modification hints in here.
« Reply #38 on: February 06, 2008, 08:37:17 pm »
Thanks stan2323 - I just modded mine, and it couldn't be simpler. Thanks for the pics and for figuring it out!
Boz
  • Last login:March 23, 2025, 03:55:29 pm
    • Battle Chasers Upright Cabinet
« Reply #39 on: June 22, 2008, 01:43:32 pm »
Thanks Mike.
The links for each image in this tut are broken. However, the larger (much larger) images for this tutorial can be seen if you save the web page contents using Firefox (and I suspect IE as well). I'm saving them for future reference should the site suddenly get hit by a bus.
