Author Topic: Rom list problem with ARCADEOS  (Read 4415 times)
CarlitoBrigante
  • Last login:July 21, 2004, 07:20:29 pm
« on: July 21, 2004, 06:07:36 pm »
Hi from a total newbie looking for some simple guidance.
Am setting up a PC with Arcadeos (2.51) and dos mame 37b16b (so I can run it on an arcade monitor).  I have Arcadeos configured so that it picks up mame from the correct directory and I have roms in the rom directory of mame but when I run Arcadeos it's not showing any games.  I try and update Arcadeos and it says it's updating with the games I have in the rom directory of mame but then it doesn't show them as available on screen.
Anybody got any ideas what I could be doing wrong please?
« Last Edit: July 21, 2004, 06:08:16 pm by CarlitoBrigante »
lokki
  • Last login:May 05, 2025, 06:18:51 pm
Re:Rom list problem with ARCADEOS
« Reply #1 on: July 21, 2004, 07:02:16 pm »
Check the configuration and make sure you have mame legacy to yes.
There's a new tag in arcadeos.cfg for legacy support:
#Legacy List Generation
legacygen=1
Set to '1' for Mame versions < .84 and '0' for versions > .84
CarlitoBrigante
« Reply #2 on: July 21, 2004, 07:21:50 pm »
Thanks for responding so quickly - do have that flag set to 1 but still nothing happens.
Any more suggestions please?
lokki
« Reply #3 on: July 21, 2004, 10:13:07 pm »
Delete the .lst files.
When arcadeOS starts it should tell you how its generating the list...
You should see something like
-listinfo %
For old versions of mame. For 84 and greater you should see
-xmlinfo | xml2info
If you don't see either then you probably don't have arcade OS 2.5.1
If you do see these and still the list is empty.... The you probably dont have the ROMS in the right place.
CarlitoBrigante2
  • Newbie
  • Last login:July 22, 2004, 04:22:07 am
« Reply #4 on: July 22, 2004, 04:27:48 am »
Thanks lokki, have tried this and note two 'interesting' things - seems to be coming up with the second message, though I definately have version 37 of mame on the machine (well before version .84) also , the file path after the message (though it is not on screen for me to make it out accurately) seems to be something like C:\ $cls .tmp (though I definately have the roms in C:\mame\roms and arcadeos.cfg pointing to mame.cfg and the rom path in mame.cfg configured to .;roms
Cheers
SirPeale
  • Green Mountain Man
« Reply #5 on: July 22, 2004, 08:53:44 am »
Don't delete just the .lst files, delete the .rm* files too.
Actually, sort the dir by date and delete *any* newly created files and try again.  Well, except arcadeos.cfg
lokki
« Reply #6 on: July 22, 2004, 09:39:53 am »
Cheers
Hi the $cls.tmp file is normal. Arcade OS creates a temporary file, and from there creates the .lst files..
I think the problem is that using the xmlinfo which is not supported in MAME 37.
Not sure you have the mame legacy configured correctly
CarlitoBrigante
« Reply #7 on: July 22, 2004, 01:57:15 pm »
Have deleted all new files in the arcadeos directory created since I installed it on C drive and tried again but still nothing
lokki
« Reply #8 on: July 22, 2004, 02:05:28 pm »
Do you still see -xmlinfo or -listinfo?
CarlitoBrigante
« Reply #9 on: July 22, 2004, 02:25:23 pm »
The message I get, reads exactly:
. Getting information list from MAME
- listxml | xml2info >C:\xl$.tmp
SirPeale
« Reply #10 on: July 22, 2004, 03:52:23 pm »
That's why, right there.  Change the legacy option from whatever you have it as, to it's opposite.
CarlitoBrigante
« Reply #11 on: July 22, 2004, 04:50:49 pm »
Thanks for the help guys have finally got Aracdeos to recognise the roms.  Tried both legacy flag options '1 and '0', to no avail.  Problem was the rompath in the mame.cfg - changed it from .;roms which it was showing previously to the full path i.e. C:\mame\roms and now Arcadeos is picking up the roms (also changed the samplepath while I was at it).
Only problem now is sound isn't working!  I only changed the rompath and samplepath in the mame.cfg and now it can't initialize the soundcard (though previously it was working when I was loading up the Arcadeos screen that didn't recognise the roms).  Arcadeos is running in a window so it shouldn't be anything to do with the dos drivers for the soundcard should it?
Sorry to be a pest.
CarlitoBrigante
« Reply #12 on: July 22, 2004, 07:03:58 pm »
 Have cracked it - reinstalled the lot and corrected the rompath and samplepath in mae.cfg and everyhting's working fine and dandy.
Thanks for all your suggestions - it's nice to know you still have some time for us fumbling in the dark newbies.
Cheers
CarliBrigante
