Author Topic: MAMEWAH SCREENSHOTS  (Read 1685 times)
scottyarc2
  • Last login:November 10, 2005, 05:33:53 pm
MAMEWAH SCREENSHOTS
« on: July 21, 2004, 03:51:17 pm »
I have now managed to setup MAMWAH and all is working very well (thanks to help from MINWAH), now i wish to add the game screen shots in MAMEWAH. So....
1) Where do the screenshots (*.png files) go, what directory?
2) I pressume i then have to direct a mamewah setting to this dir??
not sure if this is right  but this is what i would expect??
Any help please!!! ;)
TalkingOctopus
    • My Arcade
Re:MAMEWAH SCREENSHOTS
« Reply #1 on: July 21, 2004, 04:11:52 pm »
Get screenshots from the screenshot archive:
http://www.screenshotarchive.com
It does not matter where you put them because for each MAMEWAH emulator config you need to specify the directory that the screenshots are in.  For example, go to \mamewah\files\emu1.cfg and change "Artwork #1 Image Path = " to the directory with the screens.
« Reply #2 on: July 21, 2004, 04:19:19 pm »
Also just remember if you decide to use a non-standard layout, then the author may have used different Artwork #'s than you might expect.  It is a good idea to open the layout in the Layout Designer, and check the Artwork #('s) first...
scottyarc2
« Reply #3 on: July 21, 2004, 04:34:12 pm »
How easy was that, cant believe i could not figure that out myself!!!
Thanks for the help chaps ;D
apeekaboo
  • Last login:May 11, 2014, 01:27:41 pm
  • Debian addict
    • my MAME cabinet
« Reply #4 on: March 28, 2005, 05:37:57 pm »
