Author Topic: Securing Lexan to Control Panel  (Read 2408 times)
Wiliamo
  • Last login:February 28, 2009, 05:13:18 pm
« on: July 18, 2004, 04:24:20 pm »
I have my Control Panel all installed.  The buttons, Sticks,  etc... are holding down the Lexan to the CP.  When I attacth the T-Moding to the CP, how do you secure the edges of the Lexan to avoid lifting up.  I have a 8" area of nothing between the buttons and the bottom of the CP, to rest your hands and wrists.  The Lexan is not totally flat against with the CP near the T-Molding.
Thanks,
Wiliamo
Wiliamo
Re:Securing Lexan to Control Panel
« Reply #1 on: July 18, 2004, 04:29:36 pm »
Staff,
I was was having trouble staying logged on, so I looked up the anwser on this board and fixed my problem.  Then I posted this message before switching to the correct board.  Please move this post to the appropriate board.
Thank You!
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #2 on: July 18, 2004, 05:31:49 pm »
Thanks,
Wiliamo
I used screws at aprox. 1 cm (0.4") from the edge ... I like the result !
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #3 on: July 19, 2004, 02:15:35 pm »
I used these, the middle item on the page, Binding Barrels with Screw, actually found em in the 'specialty hardware' bins at Home Depot. Used 1 at each corner of the CP, gives it a nice machined look, from the top all you see is the plain end of the assembly, almost like a rivet. Aluminum is the ones I found, but it looks like you can get brass, stainless, alum, black, or plastic to fit your look
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #4 on: July 19, 2004, 04:32:04 pm »
Black screws about 1/2" away from the edge.
rdagger
« Reply #5 on: July 19, 2004, 05:51:27 pm »
I used screwposts.
http://www.screwpost.com/
Brad Lee
    • 666
« Reply #6 on: July 20, 2004, 12:13:19 am »
Thats the same thing I got above. Never really imagined there would be an entire company dedicated to that single item :)
big_garryb
  • Last login:June 09, 2006, 08:08:12 am
« Reply #7 on: July 20, 2004, 07:49:57 am »
maybe im alone in this - but i found that my buttoms screwed down were secure enough to hold the plexi down. to t-mold around the edge was fine too. everything is secure with no flappy bits.
garry
oh dear - not rain again......Scottish weather is crap, oh well - at least Mame can keep me company.
Chris
    • Chris's MAME Cabinet
« Reply #8 on: July 21, 2004, 09:35:28 am »
In my old CP I used #8 screws with finishing washers.  On my current CP I just let the buttons do the work.
--Chris
--Chris
pathdoc2
  • Last login:January 11, 2006, 08:49:53 pm
  • Your friendly pathologist
« Reply #9 on: July 21, 2004, 03:01:31 pm »
I paint my lexan control panels from underneath with paint desinged for painting lexan remote control car bodies.   After paint dries I epoxy to control panel surface.  You could just as easily put a bolt in each corner and allow the buttons to hold the lexan in place.
Totallyout2lunch
  • Last login:July 14, 2008, 01:15:43 pm
  • Tempory nOOb
    • Tree House H.Q.
« Reply #10 on: July 22, 2004, 07:08:03 am »
If you want to reall stand out from the crowd, you can cut your lexan 1/4inch smaller in all directions, and exactly route out the area for the lexan depth
Doing that only works on a good custom CP, alsong as art fits within the borders. You do not need to screw it down then as Wiliamo said the buttons etc hold it in place...
Today I marched us to the edge of the abbyss...
Tomorrow we go Forward!
Windows leads to anger,
Anger leads to hate,
Hate leads to Linux
Wiliamo
« Reply #11 on: July 22, 2004, 09:35:58 pm »
Thanks to all for the great ideas.  I'll probably go the way of Screwposts on this CP.  But I really like the idea given by TotallyOut2Lunch.  That would really look nice with the right edging around the Lexan.  Maybe for my next CP.
