Author Topic: Newbie ? about controlls  (Read 831 times)
bigdog10
  • Last login:August 04, 2004, 03:34:06 pm
« on: July 17, 2004, 05:32:34 pm »
I just got a Neo Geo cabinet that is in pretty bad shape,But iam gonna rebuild it.  Can I use the 2 joystick and buttons on the cabinet and wire it for USB or gameport?  There are many wires to deal with, or should i just buy one of those arcade X boards.  I like the feel of the neo stick though
TalkingOctopus
    • My Arcade
Re:Newbie ? about controlls
« Reply #1 on: July 17, 2004, 05:59:31 pm »
Yes you can and should use your current controls.  You wire them to a keyboard encoder like the ipac (http://www.ultimarc.com/ipac1.html).
There are lots of wires, but the wiring is actually pretty simple.  Read this (http://www.arcadecontrols.com/arcade_wiring.shtml) to get a good idea of what's involved.
bigdog10
« Reply #2 on: July 17, 2004, 06:33:28 pm »
Thanks for the response will look into that.
What one do i order if i want to use a track ball also and use usb port to save ps2 port for keyboard and mouse?
« Last Edit: July 17, 2004, 06:37:01 pm by bigdog10 »
pointdablame
« Reply #3 on: July 17, 2004, 07:15:44 pm »
To use a trackball and/or spinner, you will need an OptiPac from Ultimarc.com.  For the controls, assuming you are keeping a 2 player control setup, you need an Ipac2.
Hope that helps.
first off your and idiot
bigdog10
« Reply #4 on: July 18, 2004, 12:22:52 am »
What trackball do you recommend and I would like a 4 way joystick for pac-man and such ::)
