Author Topic: Stupid question... but...  (Read 1529 times)
Lilwolf
« on: July 16, 2004, 03:41:40 pm »
Can Windows 9x or XP handle MORE then 2 monitors natively?
I have extra monitors sitting around... and I was going to throw them away..
but then I saw this... its a decent pci video card that handles two monitors.
http://www.compgeeks.com/details.asp?invtid=PCI-MX440DDR-64MTV&cat=VCD
And I have an ATI AGP that handles 2.
And windows used to (haven't tested it recently) handle an AGP and a PCI at the same time.
But does it handle two cards that handle two each?
the drivers SHOULDNT trounce on each other.. but I could see them doing it....
but anyway, it would be a GREAT geek feeling to have 4 monitors lined up around my desk... I could out GEEK ANYONE with 4 monitors hooked to one computer!  OOOHHH YEAH!   ;D
AlanS17
    • AlanS17
Re:Stupid question... but...
« Reply #1 on: July 16, 2004, 03:43:35 pm »
Yes. And you don't need dual-monitor video cards. You just need 1 pci card for every monitor (plus 1 agp if it's available). The pci card may try to pull seniority, but you can reassign the primary window through desktop settings once it's installed.
Witchboard
« Reply #2 on: July 16, 2004, 03:48:44 pm »
Yeah, I've had 5 monitors running off 1 AGP and 4 PCI video cards.  They weren't dual cards though, but I would presume you could get 4 monitors up and running with 2 dual monitor cards.  You can setup in your BIOS which card to set as primary display (AGP-PCI) then in Windows you can set which monitor is the primary out of all the monitors.
AlanS17
    • AlanS17
« Reply #3 on: July 16, 2004, 04:40:39 pm »
That all depends on the BIOS. You don't always have the option to choose primay in BIOS. I've seen it go PCI/AGP/onboard AGP before without giving the option to choose primary.
J_K_M_A_N
« Reply #4 on: July 16, 2004, 05:01:52 pm »
Another question along the same lines...Can you have 2 monitors running at different resolutions? I have a 21" running 1600x1200 and I have an extra 17" that I could run at 1024x768 if it would work. That would be geek enough for me.
J_K_M_A_N
pointdablame
« Reply #5 on: July 16, 2004, 05:29:50 pm »
you can run multiple monitors at different resolutions at the same time.  I have a dual monitor setup on my main computer, and sometimes do this.
If your going with dual/multiple monitors, I'd really highly suggest you grab a copy of UltraMon.  It is the BEST (IMHO) multi-monitor program around.  It lets you create taskbars, disable monitors, set seperate wallpapers, etc etc.  Give it a shot.
« Last Edit: July 16, 2004, 05:30:34 pm by pointdablame »
first off your and idiot
8bit
  • Last login:June 23, 2004, 11:31:10 am
« Reply #6 on: July 17, 2004, 01:35:12 am »
having more monitor space is pretty pointless unless you need it for a reason of doing say graphics, 3d work or editing.
Havent you learned out geeking someone isnt done through how many monitors but how much hard drive space you have  :D
Jakobud
  • Last login:December 09, 2025, 12:11:34 pm
« Reply #7 on: July 17, 2004, 03:16:47 am »
Hmm I didn't know you could do this.  Can you expand your desktop to all of these monitors that are coming from your PCI slots?  Or are they just clones?
Witchboard
« Reply #8 on: July 17, 2004, 01:55:55 pm »
Yes, your desktop is expanded into the other monitors.  You can set them up side by side or one on top of the other.  The choice is yours.
pointdablame
« Reply #9 on: July 17, 2004, 05:11:13 pm »
Correct, you can expand or clone/mirror whichever monitors you'd like.  UltraMon does this very easily. Windows can also do it to a slightly lesser degree from within Display Settings.
And I'm gonna take a guess and say that 8bit has never used a multi-monitor setup.  Believe me, when you use a multiple monitor setup, you won't want to go back.  For everyday use, there are tons of reasons for two monitors.  I can also see myself using three for use with photoshop, frontpage, etc.
While I will agree that 4+ monitors may not be worth it unless you have a real reason for it, don't knock multiple displays.  They are absoultely great, and once you get used to them, you won't ever want to use a single display again.
