Author Topic: auto startup/shutdown in advmenu/linux  (Read 1616 times)
whammoed
  • Last login:Yesterday at 10:05:01 pm
  • Crack don't smoke itself
    • NiceMite
« on: July 15, 2004, 08:48:31 pm »
Does anyone know how to automatically boot into advmenu using linux? (not using X)  Also automatically shutting down from advmenu would be a plus.
whammoed
    • NiceMite
Re:auto startup/shutdown in advmenu/linux
« Reply #1 on: July 15, 2004, 09:53:37 pm »
Never mind about the startup, i found this:
http://ucsub.colorado.edu/~kelloggt/gentoomamecab.html
I recommend if you will be using linux you bookmark it and better yet print it out in case it goes away.
I still need help getting it to shut down from advmenu so any help would be appreciated.
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
« Reply #2 on: July 15, 2004, 10:42:52 pm »
I haven't dug through it yet, but I would think if you looked at the AdvanceCD scripts, you should be able to see what they are doing.  IIRC, once you leave advanceMenu, it goes into shutdown.
whammoed
    • NiceMite
« Reply #3 on: July 15, 2004, 11:15:00 pm »
there is a shutdown event (default is ctrl esc) which is supposed to call /sbin/shutdown
doesn't do anything for me though.  My user does not have permission to do shutdown though.  Maybe this is the problem and I need to figure out how to give my user this permission somehow?
