Author Topic: DC controller help  (Read 3013 times)
bleyl
  • Last login:October 29, 2004, 01:02:39 pm
  • beat 'em up guys,
DC controller help
« on: August 18, 2002, 12:35:17 am »
in arcade cabinets of street fighter, when you hit the start button during play a taunt is performed.  but in the dreamcast versions of street fighter games, you must hit the A button, followed by the start button.   what i was wondering is:   is there a way to map an extra button so that the A button is hit a split split second before the start button??  it might be hard to understand, its a ---smurfette--- to explain haha. thanks ahead of time
*BLEYL*
don't jump!
go for broke!
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:DC controller help
« Reply #1 on: August 19, 2002, 01:38:45 am »
If you buy a Madcats DC pad, you can program macros (program combos/mulitple button presses for some buttons).  Just read the manual.  Make sure the pad you buy has a macro feature (some cheaper ones don't).
-Dave
CD_Vision
  • Last login:January 23, 2010, 10:01:56 am
  • Link sez it all
    • CD_Vision's Arcade Controls
« Reply #2 on: August 19, 2002, 09:46:10 pm »
It used to be that with SF, you had to release the button to make the attack come out. Maybe if you switch your button A from normally open to normally closed that might do the trick. Assuming you use a hack. I havent tried this myself yet.
bleyl
  • beat 'em up guys,
« Reply #3 on: August 19, 2002, 11:12:26 pm »
dave-  the only problem with that, is that i need to set a button to perform the macro.   what i was thinking is-  what would happen if i wired up the two buttons (A,and start)  to a single buttons microswitch?    would it blow out the controller port or what??  i dunno
*BLEYL*
don't jump!
go for broke!
CD_Vision
  • Link sez it all
« Reply #4 on: August 20, 2002, 02:00:27 am »
No, I don't think that'd blow your ports. What would happen instead is that it'd be pausing the game everytime you threw a jab punch.
Dave_K.
    • Arcade Fever
« Reply #5 on: August 20, 2002, 02:05:51 am »
No you will not harm the joystick port wiring both buttons to a single microswitch.  But they will be hit simultaneously (so I don't know if it will work since you said they should be hit one after the other).  A joystick which support macros is really your best bet.  But I guess there is no harm in trying this first.
-Dave
