Author Topic: FE that supports PHYSICALLY rotating the monitor..  (Read 3190 times)
Hoopstar
  • Last login:June 12, 2004, 11:35:59 am
    • Hoopstars Garage
« on: July 08, 2004, 06:01:45 pm »
As my plans for my cabinet come together (and the realisation that AVGA will not allow me to play Galaga properly on a Horizontal monitor) I am investigating the possibility of using a rotating monitor like Carlos did..
I know he wrote his own FE but this is out of my skill level, so my question is...
Does any front end support monitor rotation??  Pretty much the program needs to indicate (say via the parallel port or maybe even the un-used scroll lock led) to an external circuit (something I can handle easily) if the current ROM is vertical or horizontal.
  • Last login:Today at 12:52:51 am
Re:FE that supports PHYSICALLY rotating the monitor..
« Reply #1 on: July 08, 2004, 11:43:33 pm »
It's a tad more complicated than that.......
here's what you do.
Make an interface to control your rotation.  Then make a small command line app to rotate it... (monitor.exe -ror or whatever)
Then you might get some of the developers to add support for it.  Otherwise you are on yoru own as we can't possibly know how to interface hardware we don't have.  :)
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
« Reply #2 on: July 09, 2004, 09:10:16 am »
Howards' right, Create (or get someone to create) a small command line application that rotates your monitor by signaling on your paralell port. Then it is a simple matter of calling the application when launching a game.
Kymaera would be able to do this easily.
-PacManFan
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
« Reply #3 on: July 11, 2004, 05:07:19 pm »
And just on a final note... in xp this will be difficult.
Parallel communication is wrangled by xp immediately upon bootup.  This isn't a big deal, there are ocx's and dlls to override it.  The major problem though is that all bits are "on" until your custom app gets ahold of the ports and wrangles them away from xp.
I'm having similar issues working on the universal light driver for mame.  (Don't even ask it might not ever be finished.)
« Reply #4 on: July 11, 2004, 05:14:28 pm »
Update:
I found something that might work for both of us......
http://www.eidusa.com/Interface_Boards_USB_6_IO.htm
It is a little pricey, but it's pre-made, usb, and well documented.  The 6 pins can be used for input and output, so you should be able to rig something up easily.
« Reply #5 on: July 11, 2004, 05:42:44 pm »
Update:
Pretty neat...I suppose that could also be used to power on monitors, similar to the old parallel port method.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #6 on: July 11, 2004, 06:49:08 pm »
i would like similar feature in FE for use on cocktail cab that has movable control panels on both end and on 3rd side!
AlanS17
    • AlanS17
« Reply #7 on: July 11, 2004, 10:26:52 pm »
What is this universal light driver you speak of?
Generic Eric
« Reply #8 on: July 12, 2004, 12:46:13 am »
I suspect/hope its something like L.A.M.E. dunno, but here is to hoping.  ;)
Lilwolf
« Reply #9 on: July 12, 2004, 08:52:30 am »
btw, the my almost ready for release emulator was suppost to support this.  Well.
but..
Rotation is slower then I remember.  So it will support it, but I don't think many will use it.  I was a little disappointed at javas rotation speed.  I will look at increasing the speed.  I am doing it as easy as possible.
Anyway, it will be useable if I remove one feature... but thats the main idea around the frontend.  But more of that in then next few weeks.
« Reply #10 on: July 13, 2004, 06:24:13 am »
but..
I think you are confused on the topic lilwolf.  We are talking about rotating the physical monitor, not the video output.  :)
Lilwolf
« Reply #11 on: July 13, 2004, 08:52:35 am »
No, I understood...
my (soonish to be released) frontend was designed so it would work on a cocktail table where you could take control from any of 3 sides.... and it would rotate, and update the controls used to select and launch a game.
This would be useful for a rotating monitor.  So  when you rotate the monitor, it would then adjust the skin to one that is proper for the angle viewing, (it would also update the controls, but that wouldn't be necessary here).  And then it would also allow you to change your defaults for mame (to have them run at the proper rotation).
So you could rotate the monitor, have a button switch automatically pressed when it moves  to vertical (for instance).  It would then change the skin to a vertical one, and use mames defaults needed to run all games at vertical.  It also has sets the base sort / filters to the games you want for that controlpanel/orientation.
Its all working (those features anyway) but when rotating its drawing about 1/4 speed.  And noticeable.  And thats on a decent system (2ghz).  I was hoping that the automatic rotation in java would have been more efficient (since it could be using hardware for rotation).  I'm hoping to test it with jdk1.5 soon and see if that takes care of the speed problems.
« Reply #12 on: July 13, 2004, 07:31:37 pm »
How would that be useful?   If you are going to rotate within the fe then you are in for an unenjoyable experience as you have to wait upwards of 40 seconds for the monitor to rotate even with the fastest of motors.   Imho the "proper" way to do it would be to check if the game is vertical prior to launch and if it is run exes in the following sequence:
rotateVert.exe (app that rotates the monitor)
mame.exe
wait until finished
rotateHor.exe (rotates the monitor back)
wait until finished
and then display the fe again
This way the software never comes into the equation, and it shouldn't as you are using a very expensive and complicted hardware solution to the exact same problem. Also it means that dumb goobers don't have access to rotating the monitor  (No physical button)   so they can't burn out your motors.  And the fe takes care of rotation automagically so you don't get the same dumb goober asking "U'm why is the pretty picture all sideways?"
If you are going to rotate the fe screen than that kinda defeats the purpose of physically rotating the monitor at least imho.
Lilwolf
« Reply #13 on: July 14, 2004, 12:22:19 pm »
This is how I saw it.
Rotate the monitor.
Frontend now shows up in vertical mode.
Frontend only shows the vertical games.
rotate monitor again
frontend now shows in horizontal
frontend only shows horizontal games.
I think I could even have it rotate at the speed of the turning if it took 45 seconds.  So it would show up new perfect while the monitor is in the middle of rotating.  But that would require some minor changes... And only happen if someone asks.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #14 on: July 14, 2004, 01:21:37 pm »
How about this;
Install two frontends; one vertical and one horizontal.
PC boots into the last frontend that was used, showing all games (vertical and horizontal).
Lets say it starts with the horizontal frontend:
When you select a game, instead of launching Mame, it could launch a little "CheckerApp" that checks the games orientation, if the game is vertical it rotates the monitor, then launches Mame.
When you exit a vertical game, the vertical front end would be displayed, showing vertical and horizontal games.
Does this make any sense?
« Last Edit: July 14, 2004, 01:22:46 pm by JoyMonkey »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #15 on: July 14, 2004, 01:36:22 pm »
JoyMonkey, why not even make it simpler and have a frontend that can rotate :)
JoyMonkey
    • JoyMonkey.com
« Reply #16 on: July 14, 2004, 01:53:39 pm »
I just figured it would be easier to write a tiny little app that checks orientation, rotates the monitor and launches Mame. Then it could be used with allmost any existing frontend.
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #17 on: July 14, 2004, 03:09:39 pm »
I added on request a while back an option that when the fe becomes active again after returning from a game it checks if it was a vertical or horizontal game and rotates the fe accordingly. This way the fe is always rotated correctly.
peter
