Author Topic: Centipede bezel size..  (Read 4149 times)
Hoopstar
  • Last login:June 12, 2004, 11:35:59 am
    • Hoopstars Garage
« on: July 04, 2004, 07:50:27 am »
Can anyone give me the dimensions of the Centipede bezel size - not the actual cutout but rather the entire size as I need to give these measurements to ArcadeGraphix and he is not sure if the measurements on his website are correct and I have not started construction on my Jakobud based cabinet...
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
Re:Centipede bezel size..
« Reply #1 on: July 07, 2004, 10:04:49 pm »
Are you talking the glass in front of the monitor?  If so, I should have one for a Centipede cabinet in a few days.  I'll measure it when it shows up!
Peter Baluk
  • Last login:September 30, 2006, 10:36:37 am
  • heavy load! in Brantford ,Ontario
« Reply #2 on: July 26, 2004, 11:40:22 pm »
[do you still need the sizes of bezel.Can check in mornin and let you know.Peter/quote]
IF IT HAS ,TIRES
Hoopstar
    • Hoopstars Garage
« Reply #3 on: July 29, 2004, 05:45:51 am »
yeah, just the glass in front of the monitor....
daeven
  • Llama this!
« Reply #4 on: August 02, 2004, 03:32:55 pm »
Oops!  I forgot about this question.  I've got the glass installed at home.  I'll measure the glass this evening.
daeven
  • Llama this!
« Reply #5 on: August 02, 2004, 09:14:18 pm »
The glass size is 23-11/16" x 23-11/16" edge-to-edge.  Yes, it is a square.  The artwork is not printed all the way to the edge, perhaps a 1/16" form each edge since the edges are rounded slightly.
