Author Topic: T-stik plus vs...  (Read 1913 times)
Gradius
  • Last login:February 04, 2008, 03:10:49 pm
T-stik plus vs...
« on: July 03, 2004, 04:49:31 pm »
...vs the standard T-stik. Apart from the switch on the top, are there any other differences in parts or performance of the stick? Also, what are the differences between the standard Tstik and the original model by Industrias Lorenzo. I think Andy said something about a modification he made...
microwrx
  • Last login:July 06, 2008, 09:22:02 am
Re:T-stik plus vs...
« Reply #1 on: July 11, 2004, 09:48:00 am »
The switch on both the T-Stick and T-Stick Plus are the same.  You can still switch the plus in the same way as the standard one.  The difference is the shaft is longer to accomodate the spring mechanism (plus the few parts for the mechanism itself) and there is a slot cut out of the plastic thing that the shaft presses on the switch actualtors.
NoOne=NBA=
« Reply #2 on: July 11, 2004, 04:50:00 pm »
The two big differences are that you can switch the Plus from the top, and that the balltops only fit the Plus.
Functionally, and play-wise, the guts are the same on both.
SuperRabbit0
  • Last login:July 07, 2006, 08:53:30 am
« Reply #3 on: July 11, 2004, 11:38:41 pm »
I have a regular T-Stick with a ball-top.  Works fine.  Its really a beautiful looking joystick actually...
NoOne=NBA=
« Reply #4 on: July 11, 2004, 11:49:27 pm »
Are you sure yours isn't a T-stik Plus, or possibly a J-stik?
They don't make balltops for the regular T-stik.
independentthread
  • Last login:March 01, 2005, 07:16:10 pm
« Reply #5 on: July 12, 2004, 02:51:21 pm »
My question is, how do the J-sticks stack up against the T-sticks???
The default personal text is is "I'm a llama!"???  I guess that makes me an emperor with a new a groove.
NoOne=NBA=
« Reply #6 on: July 12, 2004, 04:33:54 pm »
The J-stiks are similar in design, but have a lighter spring, and longer throw.
« Reply #7 on: July 12, 2004, 06:24:12 pm »
You might be interested in this: http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=21724
SuperRabbit0
« Reply #8 on: July 13, 2004, 08:43:46 am »
Hmmm....  Now I'm really confused.  I know I ordered a T-Stick (not a plus) and my balltop handle fits it fine.  But the Ultimarc site clearly says the balltop is for the plus only.
I wonder if I really did order a Plus (my email confirmations from Ultimarc don't list items) or the site is just not accurate....
« Reply #9 on: July 13, 2004, 09:18:56 am »
Well does the stick feature the lift & twist 4/8-way switching??  That would tell for sure...
Perhaps if you ordered a balltop Andy assumed you wanted a T-Stik Plus?
independentthread
« Reply #10 on: July 13, 2004, 09:59:19 am »
Thanks for the link Minwah, that was exactly what I was looking for.
