Author Topic: Mounting T-Stick Plus joysticks...  (Read 1777 times)
SideShow Rob
« on: July 03, 2004, 04:18:14 am »
Hi Guys,
I am about to build my own cabinet and control panel, and was wondering if anyone could give me a little info.
I want an uncluttered control panel, so seeing the 4/8 way changing mechanism of the T-Stick Plus joysticks, as reviews on RetroBlast, I thought I would have a couple of them - and cut out the need for a dedicated 4 way joystick.
I plan to mount the sticks in 3/4" MDF, from underneath - but do I need to route out an area for them to be at a playable height? Or can I just screw them in with no routing...?
Thanks for taking the time...
Rob.
Apollo
    • Eight Bells
Re:Mounting T-Stick Plus joysticks...
« Reply #1 on: July 03, 2004, 06:21:18 am »
They have pretty long shafts so probably no need to route. However it doesn't take much extra room to fit in a dedicated 4 way in the middle. How much room have you got?
SideShow Rob
« Reply #2 on: July 03, 2004, 07:36:03 am »
Thanks for the reply...
As to the space on the control panel...not sure as yet - but I am basing it on the SlikStik Classic dimensions...maybe a touch smaller, but nothing significant.
I am planning on the following:
MiniPac interface
2 T-Stick Plus Joysticks (in blue)
2 sets of 7 ultimarc pushbuttons (mixed blue and white, in neogeo config.)
1 and 2 player start
1 and 2 player coin-ins (in white)
Ultimarc 2 1/4" trackball (white) with left & right mouse buttons (blue)
Oscar Vortex spinner with 2 buttons (blue)
That takes up the 28 inputs on the MiniPac...and the trackball and spinner will hook up to it as well.
The trackball will be located lower centre; the spinner upper centre. Both sets of buttons will be located on the right of each controller. (My brother is left handed, I am right handed...when he comes round, I will be at an advantage ;) )
Each players coin and start buttons will be located above each players joystick and 7 pushbutton cluster.
So space wise...there would be room for a separate 4 way stick...but I don't want the panel to be too cluttered.
I plan on giving the MDF a couple of coats of primer, 3 coats of black gloss paint (extra tough) and then 3 or 4 coats of a clear (non-yellowing) polyurethane gloss varnish...the whole cabinet will get that treatment...hopefully will get a nice piano gloss finish all over.
If it turns out alright, I think a less cluttered control panel will not detract from the overall finish...conversely, if the paint and gloss job looks pants...i'll stick loads of buttons and sticks to detract from it  ;)
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
« Reply #3 on: July 03, 2004, 02:45:00 pm »
I routed for my t-stiks.  They have probably a little less than 1/2" and I think they are at a good height.  I guess you could mount them on 3/4 but they might be a little low you could try drilling holes and trying it on a scrap piece then and see if you like it first.
Paul Olson
    • Paul's Arcade
« Reply #4 on: July 03, 2004, 04:47:23 pm »
I routed out 3/8", it seems to be a good height.
Paul
RecycledPast
  • Last login:October 09, 2011, 09:14:47 pm
    • My 2 scratch built arcade machines
« Reply #5 on: July 06, 2004, 10:49:05 am »
I suggest testing on a scrap piece of wood.
Last night I tried a t-stick plus (long shaft w/ball top) mounted from bottom of 3/4 MDF and the height was a little lower then I'm used to.  When I mount mine I think I'll route out the wood a little.
I currently use a happs ULTIMATE which has a bat top so that might be skewing my opinion.
SideShow Rob
« Reply #6 on: July 06, 2004, 04:14:07 pm »
Thanks for the input guys...
I will test it out on a bit of scrap 18mm MDF first before I decide.
My favourite joystick from my C64/Amiga days was the Cheetah Bug joystick...which had a very short throw action, and was only about an inch long...so I am guessing/hoping that the height of the T-Stick Plus stick will be fine without resorting to routing...
Should fine out later next week..
NoOne=NBA=
« Reply #7 on: July 06, 2004, 04:34:38 pm »
The long balltops end up a little higher than Crazy Climber height with no routing on 3/4" stock.
I happen to like them that way, so I left them.
I still remember rubbing my knuckles raw playing Crazy Climber in the arcades, so I didn't want them quite that low.
