Author Topic: A few newbie hardware q's  (Read 3545 times)
richattri
  • Last login:Never
  • In the words of Socrates, "I drank what!?"
« on: May 27, 2002, 08:49:19 am »
Well, I've finally assembled all the hardware necessary to start construction on my desktop cab! But, I'm running into some limitations using very old hardware (fwiw, I'm a big fan of pre-1985 games, so I'm only running on an old P233 w/ 2 ISA+4 PCI slots). Fortunately frame rates are not my issue (though using the -nohws parm is key!) My problem is trying to find a way to make this a small enough footprint, both height and width.
So, my first question: is there such a thing as a slot L-adapter, that would plug into an ISA or PCI slot with a small height then adapt the plug to sit horizontally parallel with the motherboard? I have enough room that if I could do this with my sound and video card, I could reduce the minimum motherboard clearance from just around 7" to about 4" at worst. I know old Apple Mac LC's used to have such an adapter because of their slim height. Do PC's have any equivalent?
Second, my power supply thankfully has a power connect for the monitor (so I won't have to run a power strip inside the cab). However, it is the old style inverted monitor type. The monitor I'm using has a hardwired power cord. Anyone know where I can find an adapter to adapt the monitor style connector to a standard three-prong socket?
Finally, I want to save space by having my buttons laid out as dense as possible without weakening the wood. What is the minimum spacing between button centers (using standard 1.13" buttons) that I should use?
Thanks for any help!
Rich
mrhowell
  • Last login:August 01, 2025, 09:42:31 pm
Re: A few newbie hardware q's
« Reply #1 on: May 28, 2002, 09:14:16 am »
Never heard of a L-Slot adapter.  You might try looking for a motherboard with sound/video/network built in.  I see them at computer shows all the time (used).  As for the monitor power cord, it should be easy too replace the cord with the type you need.  As for buttons, if you use a 5/8 or 3/4 '' plywood it should not be a problem to mount buttons close together.  Plywood is very strong.
What is that pappy?
Lilwolf
« Reply #2 on: May 28, 2002, 10:15:49 am »
There isn't a L adaptor that is standard.
Some motherboards that where designed for slimline cases had this though.  but then you are spending cash.
If you want a really slick solution.  The Via 866 mhz motherboards are fanless and designed to go into small areas.
Also, look into different form factors or industrial computers.  They get more expensive, but have everything on one board.  And don't require a heat sync.
But those solutions cost more then a new board since they have limited uses.
izaram
« Reply #3 on: June 02, 2002, 03:50:28 am »
Try searching for PCI riser cards. Same for ISA (dunno if they are as easy to get). I bought a PCI riser for an car MP3 project from a local manufacturer and it cost me $20.
Found their page:
http://www.cofan-usa.com/
Hope it helps.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #4 on: June 03, 2002, 08:42:53 pm »
..... 8<...snip....
I have a local discount electronics warehouse that I source items like this....found a used one for $0.50 but here's a source for a new one:
http://www.cyberguys.com
Search for Item# 131 0430
Cost is $1.49 + shipping.
I've made several purchases from this etailer and have always been pleased with service and timely delivery.
Steve
