Author Topic: Activating a Mouse in Analog+  (Read 2615 times)
Karman
  • Last login:April 28, 2015, 10:11:46 am
« on: June 30, 2004, 11:25:59 am »
I'm running Analog+ as of this morning and am testing the split axes feature as two spinners in Tron.
In the MameanalogXP.ini I have Mouse 1 under Input Device Options and splitmouseaxes 1 under Analog+ options.
The mouse doesn't work at all when I try to move the tank tourret or Tron's arm.   In the game-specific input mappings, it has the X axis and Z axis as the dial controls.  I tried changing the fire button from ctrl to mouse button 0 and that worked.  So I know the game is seeing the mouse - I just can't seem to make it spin Tron's arm or move the tank tourret.   ???
« Last Edit: June 30, 2004, 11:42:52 am by Karman »
Tiger-Heli
    • Tiger-Heli
Re:Activating a Mouse in Analog+
« Reply #1 on: July 01, 2004, 11:56:13 am »
Start the game, press TAB, and go to the Mouse Axes menu.  There should be options there to assign a mouse axis to each player's Mouse Axis.
Karman
« Reply #2 on: July 01, 2004, 01:48:18 pm »
I don't have a mouse axis menu  ???
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: July 01, 2004, 02:58:23 pm »
Try setting -switchmiceaxes 1
Karman
« Reply #4 on: July 01, 2004, 05:18:51 pm »
Tiger-Heli is DA MAN!   ;D
Thanks!  That did the trick.
Floyd10
« Reply #5 on: July 01, 2004, 05:34:40 pm »
Ur learning this now!?
lol ;D
