Author Topic: oh my gawd what is wrong  (Read 1381 times)
flatcade
  • Last login:June 30, 2004, 05:58:50 am
« on: June 30, 2004, 04:39:57 am »
i changed the monitor in my wonderboy cab but kept the old chassis colour is good but i had to adjust the vert as it was very narrow now the screen is full size but the top half of screen  has lines that are different widths  that compresses the top half of the screen  the monitors are from different makers  but all connections are the same  any ideas ??? thnks heaps
menace
Re:oh my gawd what is wrong
« Reply #1 on: June 30, 2004, 09:03:11 am »
Going to need more info/pics before I would even hazard a guess-what make monitor came out? what went in? And i don't understand your description of the problem..
flatcade
« Reply #2 on: June 30, 2004, 09:15:36 am »
 sorry i cant post pic here for some reason a samsung screen came out  over the years it had just went black and white slowly losing its colour so i changed it which has nearly the same label on it apart from its in japanese  all connections were the same so i just used the same chassis  so when i fired it up the screen colour was spot on but  not very high so i adjusted the vertical so the game filled the screen but however the top half of the screen has crooked lines  that run from right to left  and all the lines are different widths   i can email you a pic if you mail me your address the bottom half of the screen is perfect
menace
« Reply #3 on: June 30, 2004, 10:27:44 am »
So you did a tube swap--were the vertical ohms similar?  Sounds like your vertical deflection is off and to fill the screen you are adjusting it past its sweet spot.  When that happens you get those angled lines at the top.
flatcade
« Reply #4 on: June 30, 2004, 05:02:24 pm »
so it sounds like i should call a tech lol cool thnks anyway
flatcade
« Reply #5 on: July 01, 2004, 12:23:12 am »
just had a thought before i do does anyone know how to change that or is it not adjustable ?? cheers for the info
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #6 on: July 01, 2004, 10:29:45 am »
Just put the chassis to goes to the tube with the tube. You can't exchange chassis between different monitor types as a rule.
If you don't have a chassis for your good tube you might want to get one from 8liners.
www.8liners.com
Later,
dabone
