Author Topic: Quick drying wood putty?  (Read 5497 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: June 27, 2004, 10:44:27 pm »
Well, I was really looking forward to priming my cabinet tomorrow but I ran out of wood putty.  Major bummer.  That means unless I can find a quick drying wood putty I will have to wait until the end of the week before I can even begin priming it :(
Does Home Depot or Lowe's sell any good quick drying wood putty?
Something that drys in an hour (or less) would be perfect.  I do want to do this cabinet the right way so if I should get a long-drying brand over a quick drying brand please let me know.
Thanks.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
Re:Quick drying wood putty?
« Reply #1 on: June 27, 2004, 10:58:51 pm »
I just bought some Elmer's putty at HD and it dried in 1/2hr or so.  These were just filled in screw holes.
« Last Edit: June 28, 2004, 08:56:46 am by Santoro »
sofakng
« Reply #2 on: June 27, 2004, 11:01:46 pm »
1/2 meaning a half hour?
I'm looking to mostly fill in screw holes (and a some hair-line gaps)
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 28, 2004, 12:05:49 am »
Minwax makes a very fast setting wood filler that sets and is ready to go in 15 minutes.
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
« Reply #4 on: June 28, 2004, 12:26:33 am »
Bondo. (lightweight catalyzing autobody filler)
seriously, It's non-shrinking, hardens and ready to sand in less than 10 minutes..
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
mahuti
« Reply #5 on: June 28, 2004, 01:00:05 am »
I second that. Plus, you can even build up HUGE gaps with bondo, if you just practice a little patience.
independentthread
  • Last login:March 01, 2005, 07:16:10 pm
« Reply #6 on: June 28, 2004, 01:13:00 am »
All I can say is don't buy whatever brand Wal-Mart sells.  I'm at work, and I can't think of the name of it, but I know it was in a squeeze tube and they only had one brand at the store here.  I bought that crap thinking that they would all be relatively the same, and I let it sit for a couple of days before I got the chance to paint...I used a run of the mill black latex and spots where that stuff is almost turned grey when the paint dried.  It bascially absorbed the paint instead of being coated by it.
The default personal text is is "I'm a llama!"???  I guess that makes me an emperor with a new a groove.
Gameboy.au
  • Last login:January 11, 2005, 05:54:15 am
  • Cabinet completion: 65%
« Reply #7 on: June 28, 2004, 08:35:54 am »
Selly's Plastibond.
It's a plastic putty, and you mix it with a hardener (it comes with the main tube).  Drys in roughly 20 minutes and is rock hard, meaning you can actually drill and screw into it and know it will hold.
The stuff is actually sold for puttying up metal and ceramic objects, such as tiles or fence posts.
And it costs only $7 AU.  Well worth it, and I've used it all around the place knowing that the screws I put in it will hold the monitor (and tray).
The internet, hey... so they have that on computer's now???
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #8 on: June 28, 2004, 08:56:24 am »
Sorry yes.  I will edit my post.
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #9 on: June 28, 2004, 09:05:21 am »
My vote goes to Bondo as well....  That stuff is great!
sofakng
« Reply #10 on: June 29, 2004, 08:02:48 am »
Well, my father actually picked some up for me... it was Elmer's Wood Filler.
So far I've been having fun putting the cabinet together, etc, etc... but this wood putty is a PAIN!!
Anyways I extra-filled all the screw holes (and spaces between the pieces of wood) and I'll sand it down and prime it tomorrow.
Does the wood putty need to be applied perfectly?  As I mentioned I just filled the holes (and quite a bit extra) then I plan to use a power sander to sand it so it's flat...
hyiu
    • www
« Reply #11 on: June 29, 2004, 01:56:36 pm »
that's why you should try to put all screws from the inside...
hen you don't need to care how it looks on the inside... and the outside stays perfect....
Tailgunner
« Reply #12 on: June 30, 2004, 02:30:56 am »
Another vote for Bondo. Besides the little gaps, dings, and screw holes, you can fix major cab damage with it.
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #13 on: June 30, 2004, 08:47:22 am »
I found it to be a pain if I tried to fill the screw holes flush.  Instead I applied more than was required, which made it easier to fill the hole without it 'rolling' out.  Then I sanded the extra.
