Author Topic: website photo gallery plug-in...  (Read 1943 times)
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« on: June 26, 2004, 02:08:36 pm »
I downloaded and installed gallery cause I really like the way it looks and it is supposed to be relatively easy to use.  Well, still can't get the thing to work and I think I'm giving up (I even posted on BYOAC for help, with no luck).
So I'm looking for a simple plug-in for my website so that I can document the construction of my cab (I have so many pictures, and I'm waiting for my website before I post to the Project Announcements page).
I really like the look of Gallery (I think Lance is using it on his site), so if anybody has any suggestions, that would be great.  Thanks so much!
« Last Edit: June 26, 2004, 02:09:23 pm by mmmPeanutButter »
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
Re:website photo gallery plug-in...
« Reply #1 on: June 26, 2004, 09:12:05 pm »
If you use XP you can use the CD Slideshow creator from Microsoft's XP Powertoys.
I used it to create this: http://www.mamenation.com/default.htm
SirPeale
  • Green Mountain Man
« Reply #2 on: June 26, 2004, 09:32:59 pm »
What kind of issue are you having with Gallery?  I've used it on my site, and it works beautifully.  Maybe I can help get it installed correctly.
mmmPeanutButter
« Reply #3 on: June 27, 2004, 11:04:11 am »
Couldn't be happier that you're stepping up to the plate to try to help...
Anways, I posted the information about the problem here.
and a question in addition to the link...
In the debug output, it says:
Error messages::
/usr/local/ImageMagick/convert: error while loading shared libraries: libbz2.so.1: cannot open shared object file: No such file or directory
Is that all one error or are those several errors?
Let me know what you think.
Thanks so much.
(ps...  don't have XP)
« Last Edit: June 27, 2004, 11:04:49 am by mmmPeanutButter »
SirPeale
« Reply #4 on: June 27, 2004, 06:27:07 pm »
That's good, since all my experience is with Linux.
It sounds like it can't find the libraries.  Can you verify that particular file is in that directory?  Or on your system @ all?
mmmPeanutButter
« Reply #5 on: June 27, 2004, 09:38:07 pm »
I moved the file "convert" into the folder that it mentions.
In the FAQ, it says the following:
Error in loading shared libraries -- Indicates that your dynamic library loader can't find a library that it needs. On Linux you can add the directory containing the appropriate library to /etc/ld.so.conf and then run ldconfig -v as root to fix this. If you don't have root access to the server, either contact your host for help or download a new version of ImageMagick or NetPBM and use the new install instead.
So I'm not sure about the "appropriate library" to add to the /etc/ld.so.conf file.
Could you check whats in your file and let me know what diretories are listed?  They might be ImageMagick directories, or gallery directories...  I don't know.
SirPeale
« Reply #6 on: June 28, 2004, 07:56:43 am »
I can't, actually.  I'm in the midst of a migration.
There's a bloke you can ask.  Check your PM, I've given you his email address.  He helped me with my problems with Gallery.
