Author Topic: To prime or not to prime...that is the question  (Read 2408 times)
cbmeeks
  • Last login:July 01, 2006, 09:29:58 pm
  • Metroid Classic
    • Metroid Classic
« on: June 25, 2004, 09:20:48 am »
My first instincts tell me to prime my MDF cabinet.
However, several of my buddies who have done a lot of painting said that it wouldn't be needed for something like a cabinet.  I went to Walmart and they have a paint (forgot the brand) that "guarantees one coat" and the guy there said that primer isn't needed with it.
I am on a major budget and would like to not prime if not needed.
Opinions?
cb
RETRO COMPUTERS!
A NEW place to chat about retro computers!
RETRO
METROID
Metroid Classic
Hoagie_one
  • Um....whats a cabinet
Re:To prime or not to prime...that is the question
« Reply #1 on: June 25, 2004, 10:04:27 am »
MDF soaks up paint.  I'd prime
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #2 on: June 25, 2004, 10:07:12 am »
Primer is a lot cheaper than paint.  Prime it first otherwise your first coat (or two) of paint will act as primer.
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
« Reply #3 on: June 25, 2004, 10:17:17 am »
No question, definately prime.  With decent primer you can get away with only one coat of paint (though I would recommend at least 2).
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #4 on: June 25, 2004, 10:19:18 am »
... prime at paint with with waterbased primer and ink ... and if possible do it with a gun ...  :)
It really looks good ...
Here ... see for yourself ...
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=13087;start=0
greywolf22
  • Last login:January 01, 2020, 12:45:06 am
  • My cab is always a work in progress
« Reply #5 on: June 25, 2004, 10:53:05 am »
Yup in complete agreement, with both the Prime and the gun  :)
cbmeeks
  • Metroid Classic
    • Metroid Classic
« Reply #6 on: June 25, 2004, 11:00:05 am »
I don't have access to a gun but I will probably prime.  :-)
RETRO COMPUTERS!
RETRO
METROID
Metroid Classic
fredster
  • It's all good!
« Reply #7 on: June 25, 2004, 11:26:24 am »
vote prime.
Walmart makes a spray can for  $0.94 that works okay.  Take at least 5 of them. Sand it with a 300 grit paper before you put your final coat.  It saves the good paint you don't have to use as much of it, and it costs a lot more.
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #8 on: June 25, 2004, 03:21:54 pm »
PRIME!!!  Not only does the resulting paint job look much better, and with less coats of paint - but the primer will also help keep out moisture.  This is important if you have your cabinet in a basement or something like that.
Primer on wallboard/walls is great for hiding old paint and making the new paint nicer looking - but I feel it is even more necessary on something like MDF or wood.
:) Rotate or die! :)
DennisInMN
  • Last login:December 08, 2025, 01:47:10 am
  • gunga, gunga ga lunga
« Reply #9 on: June 25, 2004, 03:50:09 pm »
I'm planning on priming/painting my cab this weekend.  Would you suggest multiple coats of primer/paint or would one coat of primer with a couple coats of paint do the trick?
chipsdad
  • Last login:July 30, 2014, 12:03:09 pm
  • Chip and Dale
« Reply #10 on: June 25, 2004, 04:04:02 pm »
Prime.  1 coat of latex based Kills or Zap.  More than one coat of primer is a waste.  Primer is used to fill in minor imperfections and prove a clean "grip" for the topcoats.
I love Windows ME.  Blue is my favorite color.
krick
  • Gotta have blue hair.
« Reply #11 on: June 25, 2004, 04:30:01 pm »
They make a special primer just for MDF.  It seals the wood and makes it more water resistant.  It comes in a can and you put it on with a roller.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
MonitorGuru
« Reply #12 on: June 25, 2004, 04:36:36 pm »
PRIME PRIME PRIME.
And don't use Latex primer.  Use oil based.  It'll help protect the MDF from swelling from water in latex and adheres better.
And yes, you can then use EITHER Latex or Oil based final coats. You cannot put oil over latex primer however.
Best deal.. a gallon of original KILZ at Home Depot is about $7 IIRC.  Will last for more than 1 cabinet and be a lot cheaper than multiple spray cans.
And sand it well between coats, and always wear a mask sanding.  You will make for a great base coat.
MDF sucks up so much that you may want to do two coats of primer.   Have them tint it closer to your final color too if you want fewer final coats.
