Author Topic: FS Belkin USB Direct Connect  (Read 803 times)
crashwg
« on: June 24, 2004, 05:49:03 pm »
Manufactured by Belkin, it is used to connect two PCs together as an alternative to a hub/router/crossover cable.  It runs on USB (not 2) therefore it isn't exactly the fastest option when it comes to networking, but it sure is easy and even a child could do it with XP.
I have no idea where the driver disk is but the drivers are readily available and if you're reading this obviously you have internet access so that shouldn't be a problem.
Also, I'm not quite sure I have the original usb cables so if you want them I'll have to buy some I think.  So I guess if you want it either way let's say the difference would be like $5 or so...  Ex. if you offer $6 for adaptor & cables, that would be $1 without!  Obviously I'm not going to let it go for $1 though, that was just an example.
Oh and BTW here's a link to Belkin's site on the "USB Direct Connect"
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=1&Product_Id=20963
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
