Author Topic: A really slick way to get PC power outside the PC  (Read 1885 times)
krick
  • Gotta have blue hair.
« on: June 23, 2004, 02:39:45 am »
I found this article and thought it was a really slick solution to a common problem.  Check it out..
http://www.bit-tech.net/article/76/
Here's a pic of the finished product to whet your appetite...
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
JustMichael
  • Mmmmm!! Cheesecake!!
Re:A really slick way to get PC power outside the PC
« Reply #1 on: June 23, 2004, 10:51:54 am »
The biggest problem with that I see is that the 5V and the 12V connections are the same physically.  What I mean is it looks like you could plug a homemade 5V device into the 12V by mistake when reaching behind the computer.  How many of you have plugged your speakers into the wrong hole when reaching behind the computer?
Hoagie_one
  • Um....whats a cabinet
« Reply #2 on: June 23, 2004, 11:12:43 am »
minor problem.
looks good to e
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #3 on: June 23, 2004, 11:16:10 am »
easily solved by using an 1/8" phono plug for the 12 volt or vice versa
krick
« Reply #4 on: June 23, 2004, 11:19:14 am »
You should never use phono plugs for power.  The way the contacts work internally, they short out as you plug it in.
Hantarex Polo 15KHz
mp2526
    • Miavio
« Reply #5 on: June 23, 2004, 11:27:13 am »
True, but I have seen it done before in consumer products, but they may have had some system to prevent damage.  Better yet, just use different size DC connectors like 5.5mm for 12 volt and 3.4 for 5 volt
« Last Edit: June 23, 2004, 11:29:13 am by mp2526 »
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #6 on: June 23, 2004, 11:28:56 am »
Just run wire into your case and plug it in to one of the pc's psu plugs it looks just as  good as this and your using the right plugs for the job!!
Gary
mp2526
    • Miavio
« Reply #7 on: June 23, 2004, 11:30:30 am »
Gary
But the whole idea is to not have to continually open the case to get to the PSU connectors, and I would say that this looks cleaner than having wires running out of your case.  Not a problem if you don't have a cover on the case.
« Last Edit: June 23, 2004, 11:31:37 am by mp2526 »
blue
  • Last login:September 07, 2006, 12:41:40 pm
  • up,up,down,down,left,right,left,right BABA ...
« Reply #8 on: June 23, 2004, 11:47:20 am »
This is a really cool idea!
I was going to be working on something similar but use USB cables and a USB hub. Feeding off the power the USB provides.
Inside a USB cable there are two wires for power -- +5 volts (a red one) and ground (a brown). There are 2 other (i believe) for carrying the data.
Ghoward
  • Mame rocks!!
« Reply #9 on: June 23, 2004, 01:30:38 pm »
Gary
Do don't have to leave the cover off you just remove one of the covers at the back of the pc where a pci card would go.
Gary
« Last Edit: June 23, 2004, 01:31:52 pm by Ghoward »
mp2526
    • Miavio
« Reply #10 on: June 23, 2004, 01:54:33 pm »
Gary
Still think that this is much cleaner looking
