Author Topic: Old cab plans scrapped.  (Read 5344 times)
Witchboard
« on: June 21, 2004, 12:06:53 pm »
New cab plans have been made.  Estimated time to start construction is 1 month.  Making final adjustments and trying to think of a name.  Cab measures 70" tall, 26.25" wide and 39" deep.  It will house a 21" monitor.  2 Player CP with modular trackball/spinner.  Admin buttons will be located on front of CP.
menace
Re:Old cab plans scrapped.
« Reply #1 on: June 21, 2004, 01:03:20 pm »
funky design but looks wobbly--you could always bolt it to the floor though  ;)
Witchboard
« Reply #2 on: June 21, 2004, 01:16:48 pm »
I don't see how it would be wobbly.  The base isn't smaller than the top.
Edit:  LOL.. well, I guess if it does wobble, I've found the name for my cab... the wobble-cade.  When I finish the project, I'll let you know.  ;D
« Last Edit: June 21, 2004, 01:49:07 pm by Witchboard »
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« Reply #3 on: June 21, 2004, 01:56:03 pm »
you may want to consider making the based slightly larger than the top.  With the monitor up high, it will be top heavy and subject to tipping over.
I am interested in how your project turns out, I want to build another cab, but running out of room in my small basement.  Have been trying to figure out how narrow I could make one with a vertical monitor, but still be stable.
luck,
edit:  re stability, the diagonals may be what you want to look at with the design of your base.
« Last Edit: June 21, 2004, 02:03:00 pm by bdsjake »
Witchboard
« Reply #4 on: June 21, 2004, 03:19:24 pm »
luck,
The base is slightly wider and deeper at the bottom than the top is.  I guess it's hard to tell at the angle the model is at.
ekopp2
  • Last login:March 30, 2006, 08:48:01 pm
« Reply #5 on: June 21, 2004, 08:00:09 pm »
Looks very cool. I'm also interested in seeing a progress update - I like the idea.
I was also going to make the same comment that Jake did - the base appears to be as wide or wider, but it doesn't have the diagonals which may affect stability.
Apollo
    • Eight Bells
« Reply #6 on: June 21, 2004, 11:39:40 pm »
Where are you going to put the PC and guts etc, looks like it could be a bit cramped?
Witchboard
« Reply #7 on: June 22, 2004, 12:03:37 am »
That may be true.  I'll let everybody know about stability issues when I build the base.
The PC is going to me mounted behind the marquee.  It will be a little tight.  I have an old ATX case where the motherboard tray slides out.  I'm going to use that a ditch the rest of the case.
This may help answer some more questions.  I've setup a site that I will use to document the contruction of the cabinet.  If there's any questions you have that aren't answered there, don't hesitate to ask.  I would still like everyone's opinions and feedback on this design.  Thanks everybody!
http://members.cox.net/witchboard
« Last Edit: June 22, 2004, 12:21:06 am by Witchboard »
hyiu
    • www
« Reply #8 on: June 23, 2004, 11:53:48 am »
usually monitor is the hottest thing... (temperature I mean...)
mounting the PC at the marquee area....
you'll need a lot of air flow to make sure it stays cool...
(hot air rises and above the monitor is where its the hottest in the whole cab....)
also... then I would recommend you use Intel than AMD....
(AMD does run much hotter....)
Witchboard
« Reply #9 on: June 23, 2004, 01:50:50 pm »
There's going to be a 115v 4 1/2" exhaust fan blowing out the back at the top of the cabinet.  I plan on having two vents in the bottom behind the side supports to cool the monitor and one in the top towards the marquee to cool the motherboard.
subcriminal
  • Last login:November 20, 2019, 12:58:00 pm
« Reply #10 on: June 23, 2004, 05:15:28 pm »
To make it stable you could mount the monitor so it faces upwards and mount a mirror in the top. It looks like it might be a bit top heavy otherwise.
Witchboard
« Reply #11 on: June 29, 2004, 09:34:16 am »
I don't think that will be a possibility, unless I use an LCD screen.  Maybe I misunderstood what you meant.
Well, I think I've come up with a name for the cabinet.  Since it seems to resemble a mushroom cloud, I think I'm going to call it Radiation Station.  I did a search on google and didn't find any cabinets already with that name.  Let me know if one already exists with that name and I'll brainstorm again.  ;)
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« Reply #12 on: June 29, 2004, 12:14:43 pm »
the biggest problem I can see with this design is:
Where are you supposed to kick it?
I kick mine all the time...that doesn't make sense to a lot of people, but I think it's makes it more authentic.  :)
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
Witchboard
« Reply #13 on: June 29, 2004, 01:19:07 pm »
Maybe I'll put a kickplate on the wall next to it.  ;D
I wasn't really aiming for an authentic(traditional?) cabinet with this project.  If I wanted to do that, I could just buy a gutted cab and put a computer in it.  I'm building this guy from scratch, so I figured I would try some new things.  The top part is removeable and if my base doesn't work out, I can always make a regular bottom to go on it, or just make it a bartop.  ;)
