Author Topic: Joystick  (Read 3052 times)
Generic Eric
Joystick
« on: May 31, 2002, 06:33:38 pm »
I don't own any arcade sticks myself, but I wonder if anyone has tried to add a "hat" to the top.
I suppose it would be easiest to do on the sticks w/ the removable top, then fashion another ball top out of wood and thread a hole to mount it on the joystick again.  There is a suitably sized hat on my dreamcast gun.
My next question is, do the joysticks have a hollow shaft?
If so, is there space to drop the wires through so the went get bent or kinked?
PCC
  • Last login:April 07, 2003, 04:12:28 pm
    • PC Cab
Re: Joystick
« Reply #1 on: June 04, 2002, 09:02:53 pm »
The Happ Top Firebutton Super Joystick has a hollow shaft.  The top doesn't unscrew, but you can heat it up and pull it off.  People have attached flight sticks to these in the past.
8-way Top Firebutton Super Joystick / Happ Part# 50-8000-10
4-way Top Firebutton Super Joystick / Happ Part# 50-4000-10
You can order just the knob/shaft as Happ Part# 50-8010-00
E-mail: info@pccab.net
