Author Topic: FOUND!: ATX power supply with switched AC accessory outlet!  (Read 10050 times)
krick
  • Gotta have blue hair.
Does anybody know where I can purchase an ATX power supply that has a "monitor outlet" on the back?
Back in the day, AT power supplies had a "monitor outlet" and it was switched via the main power switch.
There are some ATX power supplies that also have them but they are wired in parallel to the mains power and are always powered on regardless of the state of the PC.  It's essentially just a pass-through so that you don't need to plug two things into your power strip.
Any links to places to purchase one of these elusive beasts will be greatly appreciated.
If I can't find one, I'll have to break out my dremel tool make one.  I'd rather just buy it.
« Last Edit: June 21, 2004, 10:24:35 pm by krick »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Hoagie_one
  • Um....whats a cabinet
Re:Wanted: ATX power supply with "monitor outlet"
« Reply #1 on: June 15, 2004, 04:17:49 pm »
yeah, link to these please
krick
« Reply #2 on: June 15, 2004, 04:54:21 pm »
Well, here I go, answering my own post....
Vantec VAN-400B ION 400W Power Supply - $58 (free shipping)
http://www.ajump.com/ajump/product.asp?pf%5Fid=8830013&dept%5Fid=2166
This power supply has an actual AC outlet on the back.
And I'm not positive but I think it switches on and off with the power supply.
Anybody used one of these before?
Hantarex Polo 15KHz
GCS
  • Last login:August 09, 2021, 01:15:28 pm
« Reply #3 on: June 15, 2004, 04:59:18 pm »
Haven't used one of these before but I can say a few things.
1. Its a Vantec product and they make good quality stuff.  I have been using their products for some time w/o issues.
2. Back in the "OLD SCHOOL" days many AT style power supplies were like this and function in the manner you are asking it to do.
Greg
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: June 15, 2004, 05:19:01 pm »
Yes, in fact, back in the day I remember VCRs and cable boxes also had these built in, so you could switch the VCR on, and your TV would power up too.
I wonder why they don't anymore? Maybe it's not "safe"??
NO MORE!!
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #5 on: June 15, 2004, 06:00:30 pm »
No, many receivers still have these on them.  My high end Sony receiver has two or three pass thru's on it.
AmericanDemon
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
« Reply #6 on: June 15, 2004, 11:00:28 pm »
All of the Motorola Cable DCTs that my company uses still have the bypass.  We routinely will hook up a TVs power connection to the box.  So if they turn off the cable box, the TV is off too.
Hoagie_one
« Reply #7 on: June 16, 2004, 07:49:40 am »
If you end up getting it Krick, let us know if its a switched Outlet
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #8 on: June 16, 2004, 10:34:08 am »
Not to rain on your parade but....d
I'd be willing to bet it's not switched, that is, it's hot all the time if the main switch on the PS is on.
I searched high and low couple years back when I built my cab for a ATX PS with pass through cable for monitor. I found a couple but both I purchased the extra outlet is hot all the time if the main PS switch is on (even when the computer is not).
I spoke to a couple of techs (and friends) with electrical engineering backgrounds and they indicated this is by design (obviously) based on the design of the ATX PS itself.
I  ultimately went down the path of wiring a relay into a powerstrip controlled by a 12v line from the PC. Power on PC, relay triggers, powers on everything else.
Just trying to help and save you some $$.
krick
« Reply #9 on: June 16, 2004, 11:41:22 am »
I found two different reviews that claimed that the outlet switches off when the computer turns off.  A few of the reviews cracked open the case and offered pictures of the inside.  It *looks* like there is some sort of circuit attached to the outlet.  The pictures are small so  I don't know if it is a relay or just an additional fuse.
I've ordered one.  We'll see what the deal is when it gets here.
Hantarex Polo 15KHz
SteveJ34
  • Trade Count: (+9)
« Reply #10 on: June 16, 2004, 01:56:07 pm »
Well, if you found reviews that indicated it does thats a step in the right direction.
Yes, please do post the results......I don't have a need at the moment but I'd sure like to learn that such a beast exists after all the searching I did trying to find one many moons ago.
My plan was likely similar to yours.....hook a power strip to that extra outlet and away you go.
krick
« Reply #11 on: June 21, 2004, 10:23:27 pm »
OK people, I got it in the mail today and I can confirm that the accessory AC outlet on the Vantec ION DOES indeed switch on and off with the PC.
...and there was much rejoicing...
*happy dance*
This is THE solution for those who truly want the easiest cabinet power solution possible.
« Last Edit: January 02, 2006, 10:38:40 pm by krick »
Hantarex Polo 15KHz
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
Re:FOUND!: ATX power supply with switched AC accessory outlet!
« Reply #12 on: June 22, 2004, 08:11:57 am »
You might want to check how much power that switched outlet can HANDLE. I know on the back of my home theater receiver, I couldn't hook up my subwoofer to one of the switched outlets because of the power restrictions listed on the outlet....
BYOAC users get 5% off with coupon code byoac5
krick
« Reply #13 on: June 22, 2004, 03:31:23 pm »
I just fired of a question to Vantec's tech support and this was their reply...
>  Is there some sort of amp or wattage limit?
William,
There is no viable limit, short of common sense.  Don't try running a microwave or clothes dryer off the outlet.  A monitor, television, VCR, light, fan, or any combination is fine.  Most people connect a power strip to power their monitor, printer, and other peripherals tied to the computer.
Regards,
Vantec Thermal Technologies
43951 Boscell Rd
Fremont, CA 94538
Tel: 510-668-0368
Fax: 510-668-0367
Hantarex Polo 15KHz
« Reply #14 on: June 22, 2004, 04:37:21 pm »
Hrm... I wonder what they would think of using it for a projection monitor.
Sylentwulf
« Reply #15 on: June 22, 2004, 07:00:21 pm »
Wow, kick ass, glad to hear it! :)
Unfortunately I JUST ordered a smartstrip, lol.
But, on the other hand, if I can't have my mame machine microwave a hot pocket and dry my clothes while turning on dig dug, do I REALLY want it at all?
ashley-boy
  • Newbie
  • Last login:February 22, 2005, 10:48:06 pm
Re: FOUND!: ATX power supply with switched AC accessory outlet!
« Reply #16 on: February 22, 2005, 10:48:06 pm »
Has anyone ever called Vantec's Tech Support?
http://ashley-boy.blogspot.com/
