Author Topic: StepMania Help  (Read 2449 times)
Floyd10
StepMania Help
« on: June 14, 2004, 03:33:33 pm »
I want to know if it is possible to create a DWI from scratch? I tried to edit one that I dld and its too ---smurfing--- annoying. Any help would be appreciateed.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:StepMania Help
« Reply #1 on: June 14, 2004, 03:51:41 pm »
Yep, back when stepmania pwas pretty much exclusively DWI (not many people made sm files) I made my own.
It takes patients.  The hardest part is getting the bpm.  For that I had a beat calculator, in which you hit the space bar for each beat and it would give you the bpm.  Then I made a file that on each beat it had and arrow, like
alternating
Then I would use DWI (the program) in edit mode to play around with the settings until the arropws landed ont he beat towards the end of the song.  Then from there it is the tedious task of making the steps.  Though once you get the BPM you can then use Stepmania's editor to make step graphically, that will save to sm files.
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
Re:StepMania Help
« Reply #2 on: June 14, 2004, 04:36:44 pm »
Forgive a newbie to the stepmania world, but where is a good place to look for packages to download?  What is the best format to download?  Tutorial somewhere?
And if I really get into this thing, what is the best dance pad to get?
Thanks a bunch!
...they only live twice!...
(>")>----MAME----<("<)
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
Re:StepMania Help
« Reply #3 on: June 14, 2004, 07:23:19 pm »
I want to know if it is possible to create a DWI from scratch? I tried to edit one that I dld and its too <auto-censored> annoying. Any help would be appreciateed.
You might try auto-generating one:
http://www.monket.net/wiki/dancing-monkeys
I've had about 50% success rate with that, so worth a shot as it's very easy to use.
Here are some dwi tutorials:  http://www.bemanistyle.com/tutorials.php
Stepmania's main site has good selection of links and downloads.
It's my understanding that the best pad, other than one you build yourself, is the cobalt flux pad, but they're rather expensive.
Roundup of a few (less expensive) soft pads:
http://www.neoseeker.com/Articles/Games/Roundups/ddrpad04/index.html
SirPoonga
  • Puck'em Up
Re:StepMania Help
« Reply #4 on: June 14, 2004, 08:20:44 pm »
MrBond, check out www.ddrfreaks.com forum.
  • Last login:January 17, 2026, 03:40:02 pm
Re:StepMania Help
« Reply #5 on: June 15, 2004, 03:10:25 pm »
bpm calculations and stuff arent really required anymore
Stepmania has an interactive mode.... you play the song and press the arrows when you would like them to be pressed and it records them.  Then if you wish you can go back and tweak the file a little if your timing wasn't good.
Now for dwi the simulator it's quite hard to make files.  I believe your terminology is confusing everyone.  You wish to make a file to use in stepmania right?
SirPoonga
  • Puck'em Up
Re:StepMania Help
« Reply #6 on: June 15, 2004, 05:06:14 pm »
Errr, I meant ddrmaniax.net (or .com, can never remember which).
Anyway, I tried that Dancing Monkey.  Well, 4 out of 6 songs it found the bpm and gap correctly.  1 of those songs it made some weird free, it did the hard part very well, finding the bpm and gap.  Making steps after that is easy to do manually.  You could easily do that inside of stepmania.
Floyd10
Re:StepMania Help
« Reply #7 on: June 15, 2004, 05:36:45 pm »
Yeah, Yeah, Yeah. I have started on my first one: Talk to Me, Dance With Me by Hot Hot Heat. It should be good when Im done. Ok, cyas
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
Re:StepMania Help
« Reply #8 on: June 16, 2004, 09:16:36 am »
Acid has a feature that can import an MP3 file as an instrument, with a wizard to help determine BPM and such.  Works pretty well.  The other tip I've heard is once you've gotten to the point SirPoonga mentioned with the alternating arrows, play the song on 8x arrow speed, and you'll be able to tell if you've got it right.
If no one feeds the trolls, we're just going to keep eating your goats.
Floyd10
Re:StepMania Help
« Reply #9 on: June 16, 2004, 10:09:44 am »
okokokokokokokokok!!!!!!!!!! ENOUGH JARGON! :-X :-X :-X :-X :-X :-X :-X
SirPoonga
  • Puck'em Up
Re:StepMania Help
« Reply #10 on: June 16, 2004, 11:33:41 am »
What jargon?
Floyd10
Re:StepMania Help
« Reply #11 on: June 19, 2004, 04:14:10 pm »
GGKoul
  • Cheesecake Apprentice
Re:StepMania Help
« Reply #12 on: June 19, 2004, 05:34:37 pm »
Is there a site that hosts these homemade Stepmania files?
abrannan
Re:StepMania Help
« Reply #13 on: June 20, 2004, 01:16:25 pm »
Do a search for DDR tournamix.  It's a homebrew DDR file "competition" and you can get packs of the files that people have submitted.
Floyd10
Re:StepMania Help
« Reply #14 on: June 20, 2004, 01:38:03 pm »
coolies ;D ;D
MrBond
Re:StepMania Help
« Reply #15 on: June 20, 2004, 11:08:09 pm »
I checked out Dance Dance Revolution 1st Mix just to see what the fuss is about.  (Incidentally learned about bit torrent).  Stepmania seems pretty cool- but once again, you need the right controls for the correct experience :)
What pads are YOU using?  I would definately want 2 for multiplayer.
SirPoonga
  • Puck'em Up
Re:StepMania Help
« Reply #16 on: June 20, 2004, 11:29:31 pm »
You can find originals all over the place.  Frieza, one of the stepmania devs, has some.
http://frieza.stormwerks.net/stepmania/
abrannan
Re:StepMania Help
« Reply #17 on: June 22, 2004, 03:20:28 pm »
I use the DDR Deluxe 2.1 pads from www.levelsix.com with a super dual box adapter from www.electricquarter.com
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:StepMania Help
« Reply #18 on: June 22, 2004, 03:24:14 pm »
is the $6 pad good enough for a "starter" setup? I'm probably not going to get into it but my kids might so I'd like to give it a try so I'd like to find the cheapest setup possible. Looks like you can get a $20 USB adapter, so total cost would be pretty low.
SirPoonga
  • Puck'em Up
Re:StepMania Help
« Reply #19 on: June 22, 2004, 04:46:36 pm »
you (and your kids) might find that you will want better pads later, but to start out sure.  The problem with most soft pads, though, is that they drift around so as you are playing the song the pad moves out form under you.  That makes it hard to get the steps.
papaschtroumpf
  • Have a Cow!
Re:StepMania Help
« Reply #20 on: June 22, 2004, 05:28:19 pm »
I suppose I could put some non stick rug padding under it, maybe even glue it on some hard foam or plywood?
any recommendation on a XBOX->USB adapter that would work with this pad? (or a PS2 "starter" pad + adapter combination).
I have seen some XBOX->PS2 adapters but I'm already using the PS2 port for my KeyWiz and I'm worried about having daising chaining issues, so I
d rather use USB (since I have a built in USB hub below my CP).
MrBond
Re:StepMania Help
« Reply #21 on: June 22, 2004, 09:01:22 pm »
Any body use this dual PS2 converter?  I linked to it from a stepmania page.
http://www.electricquarter.com/ps2dualcont.htm
