Author Topic: New j-pac alike jamma to pc conector in USA  (Read 26220 times)
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
Re:New j-pac alike jamma to pc conector in USA
« Reply #40 on: June 17, 2004, 06:43:16 am »
and why is it that it all seems to be coming from Mexico, but he claims to be in Denver? wtf?
hmmmm....
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
Goz
  • KOTA
« Reply #41 on: June 17, 2004, 09:39:02 am »
Denver....Mexico.. what's the diff?
Been to both places, wouldn't want to live in either. Just kidding.
I think one of the guys first post says something about him being a new import from Mexico. I'm just hoping that he doesn't suffer from cranial rectitus and that the product does what he insinuates it is capable of.
I have an address and a phone numer. I'm not too worried. I know a few people in the area.
Time will tell.
-Goz
lokki
  • Last login:May 05, 2025, 06:18:51 pm
Here's the interface you have along side of the one that ode1979 is selling.
They look very similar, but there are noticeable differences. Perhaps some kind of 15hz conversion has been incorperated into it?? God only knows...
Hi,
I don't mean to knock this. I think it is a good replacement for the j-pac under DOS. (I have no experience under other OSs). I'm not entirely convinced that it replaces the arcade VGA. But even if it doesn't It is still a nice interface.
MrArcade
  • Last login:May 29, 2025, 02:06:06 pm
  • I wish I had time to play these games !!!
Something else that I don't understand.....the 7th finger on a jamma connector is missing as a key slot.  The female jamma connector has a "bar" there.  This prevents it from being plugged in backwards.  If this is jamma, where is the keyway?
http://www.arcadetreasure.com/techinfo/techinfo.htm
Oh, the memories of living on pizza subs and Dr Pepper...
android
  • Last login:August 21, 2006, 09:44:47 am
After looking at the pictures above, doing some research on scan converters and scratching my head, here's my best guess on what this is. Please note that I may be wrong, but given Ode's reluctance to provide additional information, I'll have to trust my instincts.
As I mentioned in the other thread, this thing will allow you to connect your PC through Parallel, Serial and Audio ports to your JAMMA rig. However, here are the caveats:
1. Since it connects to the parallel port, you will need to use a TSR/driver (SNESKEY/PSXPAD) to convert parallel input to keypresses. Configuring the drivers may require some extra work. Conclusion: no advantages over the plug-and-play functionality of JPAC.
2. I originally assumed that this device would include a scan converter, but given the complexity of converting a 31khz VGA signal into 15khz (and that ShagMame only has 6 chips, none of which is VLSI) I have strong doubts that this thing will include scan converting circuitry. Therefore, I have to assume that this connects your VGA directly to the RGB monitor, which spells disaster if you don't change the scan frequency from 31khz to 15khz *through the video card*. Therefore, you will have to reprogram your card to output 15khz using MONARC, ArcadeOS, AdvanceMame, etc. and the ATI / Blade 3D cards.
Conclusion: not even close to the functionality provided by ArcadeVGA nor a good scan converter (i.e. Extron Emotia).
Based on the assumptions above, here's a comparison table between the two devices. (Please note that I'm not including the ArcadeVGA into the comparison, as I believe the ShagMame is closer to the JPAC than to the JPAC+ArcadeVGA combo).
Feature .........................................JPAC................ShagMame
Jama fingerboard............................yes.....................yes
Input to PC through................keyboard port........paralel port
Requires port drivers.......................no......................yes
Requires video drivers....................yes......................yes
Protects Arcade Monitor..................yes.......................no
Requires software config(1).............no.......................yes
PC audio port connection.................no.......................yes
Can use in Windows.......................yes.......................yes(2)
Notes:
(1) Besides the configuration required to drive an arcade monitor.
(2) With appropriate parallel port driver: SNESKEY for DOS/Win9X, PSXPAD for XP/2000
Final conclusion: A Jpac provides better functionality, more flexibility and true plug and play requiring no drivers for the controls. Regarding video, they are equivalent, just acting as a VGA passthrough. However, the JPAC provides safety so that you won't burn your arcade monitor if you accidentally send 31khz through the VGA port. Unless you absolutely have to use the parallel port, JPAC is the way to go.
Final disclaimer: these are just my assumptions and opinions based on them. If ode wants to challenge them, I'll be glad to hear from him; I'd love to be wrong, as this would be a killer product. However, there's a reason why nobody has done it yet.
-- Android
P.S. - Edited 6/18 to include lokki's corrections regarding video drivers
« Last Edit: June 18, 2004, 11:13:18 am by android »
Goz
  • KOTA
Feature ..............................JPAC................ShagMame
Jama fingerboard.................yes.....................yes
Input to PC through......keyboard port........paralel port
Requires port drivers.............no......................yes
Requires video drivers..........yes......................yes
Protects Arcade Monitor........yes.......................no
Requires software config.......no.......................yes
Connects audio to Jamma......no.......................yes
Can use in Windows..............yes.......................??
Final conclusion: don't even bother. A Jpac provides better functionality, more flexibility and true plug and play requiring no drivers. And it provides safety so that you won't burn your monitor.
Final disclaimer: these are just my assumptions and opinions based on them. If ode wants to challenge them, I'll be glad to hear from him.
-- Android
I suspect you are correct and we have to assume this is accurate until we actually see the device in use and or the documentation that will only be provided with the product.  I volunteered to be the "Guinee Pig" (more balls than brains) because while I like Andy's products, I wished for a cheaper solution than ArcadeVGA + JPAC and then to potentially still have to add in an IPAC and wiring speakers when a cab is already has them.  I am not knocking the ArcadeVGA + JPAC combo... hey how else can you connect a PC to an ARCADE montiro in less than 5 minutes? Maybe there is another solution... maybe there isn't. It'll be fun to find out.
With any luck we are a few days away from finding out.
-Goz
ps if it only works in DOS then ODE has shot himself in the foot as far as starting a business. Not due to only supporting the one OS, but in failing to communiicate this critical bit of info.
lokki
1. Since it connects to the parallel port, you will need to use a TSR (SNESKEY) to convert parallel input to keypresses. Therefore you can only use it on DOS. Conclusion: no advantages over the versatile JPAC.
There are some drivers for parallel encoders..
http://www.psxpad.com/index_e.php
http://www.geocities.com/deonvdw/Docs/PPJoyMain.htm
I haven't test them or know if they work with this card
android
Thanks lokki. I stand corrected. Also, SNESKEY can be used with Windows 9X.
-- Android
ode1979
  • Last login:July 07, 2004, 03:44:09 pm
« Reply #48 on: June 18, 2004, 03:00:56 pm »
Hi folks sorry for the delay but i was out of town and having some problems...i see a lot of people dont like my idea of not given so much information about my product and thats ok, i know that when i getmy review some people will thinks the product its nice and others will think it suck's but thats the way life goes and has far has i can tell about my  self .....this its not a scum and if my name its not under my phone number its cus its under my dad's name and if you dont mind why dont you try to call me and ask me all the questions you got in mind...ill be glad to answer them....i got more then one year studing english so i dont speak very well but i do can comunicate nicely....just dont make any more negative coments on this and wait untill "gozur" gives hes opinion about'it....thanks guys  ;D
ode1979
Hi guyz...why dont you guys talk all you want in this place http://www.arcadecontrols.org/yabbse/index.php?board=2;action=display;threadid=20544  here you can make your opinion and see what the advace its in my product and let this space for future orders...like it its..otherwise i may have to ask the moderator to close this space....thanks ;D
SirPeale
  • Green Mountain Man
« Reply #50 on: June 18, 2004, 03:15:37 pm »
I merged both topics together, since they're interelated.
ode1979
« Reply #51 on: June 18, 2004, 03:23:25 pm »
Thank you sir..... ;D
android
« Reply #52 on: June 18, 2004, 06:05:37 pm »
Ode,
El problema que todos tenemos es que, por la poca informacion que has dado, nadie entiende a ciencia cierta como funciona tu tarjeta y lo unico que hacemos es especular. Te propongo algo: porque no me explicas exacta y detalladamente como configuras la PC para que funcione con tu tarjeta y el JAMMA cab? You podria traducir la informacion y publicarla para beneficio de todos.
Puedes responder a spaceduel(at)yahoo(dot)com
-- Android
P.S.- Oops... should've used PM. Oh well....
« Last Edit: June 18, 2004, 06:06:28 pm by android »
Goz
  • KOTA
« Reply #53 on: June 18, 2004, 07:46:03 pm »
Hoagie_one
  • Um....whats a cabinet
« Reply #54 on: June 19, 2004, 09:59:10 am »
Ode,
-- Android
Translated for all
The problem that all we have is that, by the little information that you have given, nobody understands for sure as works your card and the unico that we do is to speculate. I propose something to you: because you do not explain to me exactly and in detail as you form the PC so that the JAMMA works with your card and cab? You podria to translate the information and to publish it for benefit of all. You can respond spaceduel(at)yahoo(dot)com
GameDork
  • Last login:March 06, 2011, 07:56:45 pm
  • I installed a DDR Pad on Tom Cruise!!
« Reply #55 on: June 22, 2004, 01:01:22 pm »
Gozur:
Have you recieved it yet?
Donkey Kong Hi Scores:
1) 169,600
2) 164,300
3) 134,000
4)116,800
5) LOL!
Goz
  • KOTA
« Reply #56 on: June 22, 2004, 03:13:20 pm »
Sorry for the lack of update.
I ordered it last week and ODE recv'd payment on Friday and shipped it yesterday (haven't confirmed). Colorado is 2 days shipping to California so I should see the package tomorrow.
-Goz
GameDork
« Reply #57 on: June 23, 2004, 08:53:46 pm »
Anything Yet?
1) 169,600
2) 164,300
3) 134,000
4)116,800
5) LOL!
SirPeale
« Reply #58 on: June 23, 2004, 08:56:39 pm »
Anything Yet?
Dude, calm down!  When he's ready he'll post.
Goz
  • KOTA
« Reply #59 on: June 23, 2004, 09:37:04 pm »
It didn't arrive today.
I'm going to request a tracking number etc..
I'm eager to check this thing out and have fresh batteries in the digital camera and will make available pics of everything from the board, software, documentation, packaging, and of course experience with setting it up, etc.
Oh crap that means i have to clean the game room.... damn!
-Goz
GameDork
« Reply #60 on: June 24, 2004, 03:56:14 am »
Anything Yet?
I just want to know if thing is real! Before I pay  $150  to Ultimarc!!
I WON'T CALM DOWN!!!!!!!!! ;D ;D
1) 169,600
2) 164,300
3) 134,000
4)116,800
5) LOL!
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #61 on: June 25, 2004, 08:26:02 pm »
This thread died.  IT may be time to get that $150 to Ultimarc.   ???
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
Goz
  • KOTA
« Reply #62 on: June 26, 2004, 12:36:37 am »
It slowed down, but did not die.
I recv'd it today. Unfortunately I haven't had much free time tonight until now.
I need some info from ODE before I can proceed in reviewing the product. With any luck I will get a response some time soon.
The product arrived with zero documentation. There are a few wires that are not painfully obvious where they need to be connected. Since i don't have a full feature list, I am hesitant to simply guess and possibly hose the system or the JAMMA cab.
I'll keep you apprised how things go and will try to have some sort of review available by end of the weekend.
-Goz
Hoagie_one
« Reply #63 on: June 26, 2004, 03:58:25 pm »
im shivering with anticipation
lokki
« Reply #64 on: June 26, 2004, 06:25:35 pm »
-Goz
Hi,
As far as I can tell the cables are
1) Parellel
2) video
3) sound
4) 5v power???
Goz
  • KOTA
« Reply #65 on: June 26, 2004, 07:33:22 pm »
Hi,
1) Parellel
2) video
3) sound
4) 5v power???
Its the guessing on the mystery twisted pair that has me wondering. Would you want to guess that it's for 5v power and just connect it?
-Goz
lokki
« Reply #66 on: June 26, 2004, 08:26:39 pm »
Hi,
1) Parellel
2) video
3) sound
4) 5v power???
-Goz
My guess is (I have a similar card but haven't used it) that it is power for the sound Amp.
Goz
  • KOTA
« Reply #67 on: June 28, 2004, 02:25:17 am »
Still awaiting info from ODE.
As soon as I get the reply wiith the features it has so i can accurately evaluate each feature and get the documentation for the jamma orientation and the undefined twisted pair. i will drop everything to review it.
-Goz
Goz
  • KOTA
« Reply #68 on: June 29, 2004, 10:24:08 am »
I plugged it in last night and while I am still awaiting info from ODE and some help troubleshooting a display problem. I figured I'd drop you a line and at least confirms that sound does work via the Shag MAME and the JAMMA harness.
I'd like to give ODE the chance to help me get the video set right before posting pics, but I'll say that the initial video seen on the monitor was not pretty. Once the video is sorted I'll move on to the controls aspect.
-Goz
menace
« Reply #69 on: June 29, 2004, 10:43:47 am »
I would think Ode would be a little quicker since you are now basically his marketing department--keep that in mind--if it wasn't for you, he would sell 0 units....  if I was ode I would be calling you every 10 minutes to see how you are getting along and to see if you had questions.
My opinion at this point is that even if it would save a few bucks compared to ultimarc's stuff, i would much rather deal with someone who stands behind their product, offers technical support, has a legitimate business,  doesn't threaten to ask to close threads if there are negative discussions..etc, etc.
Ode has a lot to learn about selling new prodcust and I for one don't like being a guinea pig (no offence gozur, you are a braver man than I)
SirPeale
« Reply #70 on: June 29, 2004, 10:56:16 am »
I'm betting it's just a keys interface to controls.  You'll likely have to set the modes for video yourself.
Goz
  • KOTA
« Reply #71 on: June 29, 2004, 11:37:14 am »
ODE had mentioned right from the beginning an option for someone to purchase the patent. I was really interested in finding out if this could be product that a reputable company would pick up. For instance if it delivers everything that is halfway articulated / implied it could be something that Ultimarc, Happ, GroovyGame Gear might be interested in acquiring.
I am disapointed so far in the communication in regards to the product and as ODE stated he is new to this. I would think though that if someone wanted this to be their lively hood that there would be better response, documentation provided, and upfront feature list.
I will continue to eval the product and write up a review for it, but so far it's not looking too good.
If Kevin or another wants to take a crack at a review for it, I will ship it to them as stated before.
-Goz
pointdablame
« Reply #72 on: June 29, 2004, 01:38:03 pm »
The lack of info from ODE leaves a bad taste in my mouth, thats for sure.  This is definitely not the way to sell a product.
first off your and idiot
android
« Reply #73 on: June 29, 2004, 03:30:55 pm »
Do the IC chips in your board have any numbers? can you post them? from those I could figure out once for all if it has scan conversion circuitry.
-- Android
Goz
  • KOTA
« Reply #74 on: June 29, 2004, 03:41:58 pm »
I'll be at work for the next few hrs.
Here's a pretty decent pic that you should be able to make out the chips.
Hope this helps
-Goz
android
« Reply #75 on: June 29, 2004, 06:45:04 pm »
Unfortunately couldn't read the numbers printed on the chips... ???
« Last Edit: June 29, 2004, 06:46:04 pm by android »
Goz
  • KOTA
« Reply #76 on: June 29, 2004, 06:55:26 pm »
Here are the #'s on the chips
44F7N5K
CD4021BE
All 6 chips appear to have the same numbering.
-Goz
android
« Reply #77 on: June 29, 2004, 07:57:42 pm »
The chips are all CD4021's. They are all 8-bit shift registers. A shift register takes parallel input (i.e. buttons) and converts it to serial.  Sorry. No scan conversion circuitry at all. After scratching my head for a while on why they would convert from parallel to serial and then parallel again for the PC port,  I found an interesting piece of information on the net: can you guess what chip is used inside the SNES controllers? yep. CD4021.  So basically, what ODE is selling is a glorified NES controller.  It shouldn't be too difficult to clone the ShagMame with  a few modifications to this: http://mind.riot.org/elektronik/NES%20Controller%20Schematic.html
-- Android
« Last Edit: June 29, 2004, 08:14:53 pm by android »
GameDork
« Reply #78 on: June 29, 2004, 09:04:33 pm »
Where i s Ode? He seemed to reply often until he got the $45 and now he has been nowhere to be seen. If he held the "patent" for this, would he not know what its specs were?
I think he had nothing to do with the building of this and has no idea what it can/can't do.
1) 169,600
2) 164,300
3) 134,000
4)116,800
5) LOL!
lokki
« Reply #79 on: June 29, 2004, 09:11:55 pm »
-- Android
Hi,
I had posted previously on the thread..
http://snespad.emulationworld.com/welcome.html
Includes diagram for use with sneskey
