Author Topic: Sorting MAMEWAH ROMS? NEo Geo Questions  (Read 2967 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: June 10, 2004, 11:55:56 am »
Hello,
I was wondering how I can sort my complete mame list and make a NEOGEO list. BUT have all the neo geo games in a NEOGEO layout? so its just them.. I dont want a custom list within the mame layout. I want a neo geo page... ayone advise?
Nebula-it plays all the neo geo games? what is CPS2, CPS1 etc? but mame does that too? why bother with KAWAKS or NEBULA then? I just want neo geo section
thanks
Jim
« Last Edit: June 10, 2004, 11:57:50 am by Demon-Seed »
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
Re:Sorting MAMEWAH ROMS? NEo Geo Questions
« Reply #1 on: June 10, 2004, 12:32:07 pm »
What if you just set up a 2nd emulator running Mame but have the only list be a filtered custom list with Neo-Geo (BIOS)roms.  With a 2nd emulator you can have a totally different layout and everything.
Just change the Emu name to "Neo-Geo" to mask that it is actually running Mame.
I think that would be the simplest way.
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
Demon-Seed
« Reply #2 on: June 10, 2004, 08:01:33 pm »
Hey ok
that would work thanks
Demon-Seed
« Reply #3 on: June 10, 2004, 08:03:11 pm »
how do i filter just neo geo?
TalkingOctopus
    • My Arcade
« Reply #4 on: June 10, 2004, 09:57:36 pm »
You filter by bios in mamewah.  Select only the neogeo bios.
« Reply #5 on: June 11, 2004, 04:27:22 am »
What I would do is have 2 custom lists, 1 for NeoGeo and the other for all other games.  Then make a layout for each list - MAMEWAH now supports different layouts for each custom list, so you don't need to set it up as 2 emulators :)
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« Reply #6 on: June 11, 2004, 08:09:15 am »
BTW Minwah, this was an awesome addition to your FE.  I love having my Classics list have a different look than my Fighters list.
THANKS!
« Reply #7 on: June 11, 2004, 11:32:27 am »
Glad you like :)  I hadn't thought I would use this feature but I may make a slight change to my layout for each custom list - I use different lists for each control panel...
simplygriff
    • simplygriff.com
« Reply #8 on: June 11, 2004, 01:30:05 pm »
I thought having custom list layouts would work but I wasn't 100% since I didn't have it in front of me.  Just do that and you'll be set.  Good luck!
-G
www.simplygriff.com
Demon-Seed
« Reply #9 on: June 15, 2004, 12:32:55 pm »
hey
ok how to i do the bios thing???? filer just neogeo?
simplygriff
    • simplygriff.com
« Reply #10 on: June 15, 2004, 12:40:30 pm »
Yeah
Just leave Neo-Geo as the only "yes" and turn all the others off or set to "no".  Exit and it will refresh the list.  Good luck.
-G
www.simplygriff.com
Demon-Seed
« Reply #11 on: June 15, 2004, 01:26:25 pm »
Hey
Great thanks I figured it out! thank-you.
simplygriff
    • simplygriff.com
« Reply #12 on: June 15, 2004, 01:34:22 pm »
Cool.  Glad you figured it out.  Do you already have a catver.ini file?  With that you can sort out lists based on catgories.  I have one list that is just "versus fighters"  That maybe of some interest to you in the future.  If you want the file go here http://www.catver.com/
www.simplygriff.com
Demon-Seed
« Reply #13 on: June 15, 2004, 03:32:31 pm »
Hey
Yea that is what I am working on. Many people who played mame had complaints of going through 4000+ roms.. so what I did was made um Neo geo list, Light gun list, and soon, fighter. and then the mame list is reduced to the others. What other categories? can i filter like classics? ie) pacman etc..... with the catver of course not manually... maybe sports.....and driving. any suggestions??
Also I want to add a few pc games too.. can they be added to the lists? like if I have mame sorted into LIGHT GUN. can i have PC version of house of the dead there too?
Mamewahs filters are great!
« Last Edit: June 15, 2004, 03:35:03 pm by Demon-Seed »
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #14 on: June 15, 2004, 08:14:10 pm »
At this stage I don't believe you can mix lists of different emulators.  However Minwah may implement this in the future. (if he gets enough people nagging him about it. ;) )
For those of you who are unsure about creating custom lists within Mamewah using the catver.ini file I have put together a short demonstration video showing how it is done.  You can get the video here.
Demon-Seed
« Reply #15 on: June 16, 2004, 09:07:26 am »
Hey
I think that would be just a great future.. Thanks for the video I could have used it! :P
Demon-Seed
« Reply #16 on: June 16, 2004, 09:41:43 am »
Ok the filters dont want to work right with mame. I set up fresh and it shows all filters but doesn list CATEGORY in the filters list? if I put in a second copy in mamewah to same directory the category section is seen in the filter list in the second copy but none of the others?? very, very weird
« Reply #17 on: June 17, 2004, 05:45:17 am »
After you placed catver.ini in your MAME folder, refresh the Main List and the Category Filter will appear.
BTW Triggerfins catver from www.mameworld.net/catlist is an alternative (probably more accurate) to the one from catver.com...
simplygriff
    • simplygriff.com
« Reply #18 on: June 17, 2004, 11:34:05 am »
I knoew ther was a better one but I couldn't remember where it was and when I gogled it That one didn't come up.
-G
www.simplygriff.com
