Author Topic: White plastic spacer tube for joysticks  (Read 792 times)
andrewbubp
  • Last login:March 20, 2007, 09:25:21 am
« on: June 10, 2004, 09:16:17 am »
Can someone tell me the over all length of the long spacer and any substitutes you may have used if you need yours and no longer had it.
Re:White plastic spacer tube for joysticks
« Reply #1 on: June 10, 2004, 10:45:49 am »
Dunno about anyone else but I've got no idea what that means  ???
Could you explain some more?
NoOne=NBA=
« Reply #2 on: June 10, 2004, 11:24:18 am »
My guess is that he wants the length of Happ's long spacer, used on their comps/ultimates/etc...
The EXACT length is not super critical.
They just need to be long enough to hold tension on the spring and stick when fully assembled.
Happ's website looks like it lists them as .86"--if you go to the checkout cart and put in that part number.
They sell them for $0.71 ea.
I don't know if they have a minimum order though.
As far as substitutes go, anything that will fit around the shaft of the stick, not interfere with the throw on it, and not rub against other parts should work.
You might try getting some spacer material, designed to go around all-thread, and use a washer at the bottom of it.
andrewbubp
« Reply #3 on: June 10, 2004, 01:04:23 pm »
The long spacer is what I was looking for. Thanks
