Author Topic: What games use a spinner?  (Read 68117 times)
cbmeeks
  • Last login:July 01, 2006, 09:29:58 pm
  • Metroid Classic
    • Metroid Classic
« on: June 09, 2004, 09:29:52 am »
I want my CP to be lean and mean and if it's just "breakout" type games, then I can do without a spinner.
-cb
RETRO COMPUTERS!
A NEW place to chat about retro computers!
RETRO
METROID
Metroid Classic
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
Re:What games use a spinner?
« Reply #1 on: June 09, 2004, 09:58:24 am »
(Online database - Listing games by control)
via: http://fe.donkeyfly.com/controls/gamesbycontrol.php
Spinner
Arkanoid (World) arkanoid
Arkanoid - Revenge of DOH (World) arknoid2
Blasteroids (version 4) blstroid
Wolf Pack (prototype) wolfpack
Tempest (rev 3) tempest
Tron (set 1) tron
Mad Planets mplanets
720 Degrees (set 1) 720
Aztarac aztarac
Forgotten Worlds (US) forgottn
Kozmik Kroozr kroozr
Crater Raider crater
Wheel Of Fortune wfortune
Victory victory
Two Tigers twotiger
Up/Down Spinner
Discs of Tron (Upright) dotron
Zwackery zwackery
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #2 on: June 09, 2004, 10:12:44 am »
There are A LOT more than that, not sure why that website missed a bunch.  If you look in the Mame games list and look for a control of "dial" you see all of them.  If you do not have a steering wheel, a spinner can be used to drive.
:) Rotate or die! :)
« Reply #3 on: June 09, 2004, 10:46:53 am »
I was thinking this today myself, since I am in the process of making my trackball/spinner/analog stick panel...
I used MAMEWAH's Input Type and Category (catlist) filters, to give a list of non-driving spinner games:
720 degrees
Aqua Jack
Arkanoid
Atari Mini Golf
Aztarac
Beatmania (all)
Blasteroids
Boxing Bugs
Burmuda Triangle
Caliber 50
Cameltry
Car Polo
Cerberus
Cosmic Chasm
Cyvern
Dark Planet
DownTown
Embargo
Exterminator
Fighting Soccer
Forgotten Worlds
Gals Panic 4
Gals Panic S - Extra Edition
Gals Panic S2
Ghox
Gigas
Gigas Mark II
Gondomania
Guerilla War
Guts'n
Heavy Barrel
Hiphopmania Complete Mix 2
Ikari III - The Rescue
Ikari Warriors
Jan Jan Paradise
Jan Jan Paradise 2
Kaiser Knuckle
Kick
Kozmik Kroozr
Major Havoc
Midnight Resistance
Moonwar
Off the Wall (Atari)
Off the Wall (Sente)
Omega Race
Panic Street
Plump Pop
Pop 'n Bounce / Gapporin
Prebillian
Puzz Loop
Quester
Razzmatazz
Riddle of Pythagoras
Road Blasters
SAR - Search And Rescue
Sengeki Striker
Sen-Know
Star Trek
Subs
T.N.K. III
Tac/Stan
Tel Jan
Tempest
Time Soldiers
TouchDown Fever
Tron
Two Tigers
Victory
Victory Road
Vs Block Breaker
Vs Mahjong Otome Ryouran
Wall Crash
Wheel of Fortune
Wolf Pack
Zektor
Zwackery
Since the 'dial' input type in MAME is incredibly inaccurate, I started going thru the games to see which could actually be played with a dial - see the attached Excel sheet (rename to .xls) my WIP list.  The 'y/n/?' column is for my benefit, basically this is whether I can play the game on my panel or not.  Ones which are not playable are generally rotary stick games or games with unique controllers.  The list isn't great, but might be of some use :)
BTW if no-one has Excel post and I'll convert it...
Edit: just wanted to say that this list is generated from MAME v0.83, and doesn't include clones.
Edit 2: Car Polo slipped thru as it is classed as 'Sports', and Road Blasters as I didn't think to filter out 'Shooter / Driving' games.
« Last Edit: June 09, 2004, 10:50:30 am by Minwah »
cbmeeks
  • Metroid Classic
    • Metroid Classic
« Reply #4 on: June 09, 2004, 10:54:54 am »
Well, looks like I am buying a spinner...lol
So, do they work well for driving games???  Outrun??
cb
RETRO COMPUTERS!
RETRO
METROID
Metroid Classic
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: June 09, 2004, 10:56:31 am »
Roadblasters is optical 270-degree yoke, so I think it should stay in anyway.
« Reply #6 on: June 09, 2004, 10:58:56 am »
Yeah the reason I said that is I filtered out ALL driving games, as I'm not interested in them for my analog panel (I am making a separate steering wheel panel you see...)
« Reply #7 on: June 09, 2004, 11:00:29 am »
Won't work well with OutRun as that used a ~270deg wheel (POT based).  It will work very well for games which originally used spinner type wheels, eg Pole Position, APB, Super Sprint etc...from memory there are ~35 of those.
Edit: exactly 35 ;)
« Last Edit: June 09, 2004, 11:03:13 am by Minwah »
kevin
  • Last login:October 24, 2004, 08:45:38 pm
« Reply #8 on: June 09, 2004, 05:47:20 pm »
Do the beatmania/hiphopmania games really use a spinner? I thought the turntable was just a fancy mechanism for hitting one of two (clockwise/counter-clockwise) switches. As long as the turntable is moving, the button is 'pressed'.
In MAME, buttons 6 and 7 are both for the turntable, and you need both of them to play properly. While playing a song, quick sucessive presses of a single turntable button are ignored, forcing you to alternate between the two buttons, ie make a scratching motion. I'd imagine this is because there is no set scratch distance on the turntable so the software ignores the presses for a very short duration to compensate for long or jerky scratches.
I'm not familiar with how spinner input is handled in MAME, but is it possible to have one direction of the spinner act as a button press, and the opposite direction to act as a different button? If so, you could come up with a cheap turntable top for your spinner and stick some buttons in the beatmania config and have a cheap controller for a very fun game.. Assuming you already have a spinner.
Anyways, didn't mean to hijack the thread, but I guess it's still spinner-game related.
-Kevin
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
how many fire buttons for spinner games?
« Reply #9 on: June 09, 2004, 07:53:58 pm »
i am thinking of building removable CPs for my cocktail cab and so currently thinking of builiding one CP with a spinner (i plan to have another with a TB and 3 buttons - for missile command;)
just wondering how many fire buttons would be required for a spinner CP?
i suppose most spinner games don't need many fire buttons.
would just 1 fire button be sufficient or more required?
« Reply #10 on: June 09, 2004, 08:49:00 pm »
If that is so, then chances are it is not properly emulated in MAME.  Like SNK rotary sticks are treated as dials I believe, but do not use optics...
Re:how many fire buttons for spinner games?
« Reply #11 on: June 09, 2004, 08:52:39 pm »
I'm building a trackball/spinner/analog stick panel atm...so I have 3 buttons for Missile Command, and that should cover spinner games.  I think some spinner games use 2 buttons, oh, and Blasteroids uses 3.
NoOne=NBA=
« Reply #12 on: June 09, 2004, 10:13:54 pm »
Star Trek uses 4.
kevin
« Reply #13 on: June 10, 2004, 02:07:44 am »
I'm just going by what I've observed while playing beatmania/hiphopmania in MAME. I've only had the chance to play it in arcades a few times. When the subject of beatmania as a spinner game came up, I just knew that mame treated the turntable as buttons and not a spinner. Someone who has experience with the actual arcade hardware would likely know for sure.
-Kevin
rchadd
  • Made in Cornwall
Control FE with Spinner CP?
« Reply #14 on: June 10, 2004, 05:07:24 am »
If i implement a removable CP with just a spinner and 3 buttons - will i still be able to control the FE? For example will the spinner allow me to scroll up/down and select a game in the list?
Or would I have to use one of the joystick CPs to use the FE?
Currently undecided on which FE to use - currently thinking about using MameWAH. Any recommendations?
The only thing with MameWAH is that it doesn't allow different emulators in the same game list - or am i wrong???
basically i would like all playble games listed in a single list (mame,espxe,daphne,pc games). it should support both horiz and vert displays. ideally it would support joystick, TB and spinner control operation.
Tiger-Heli
    • Tiger-Heli
« Reply #15 on: June 10, 2004, 07:13:56 am »
-Kevin
It's very likely that MAME uses either buttons or spinner input for this.  For example, in Arkanoid, you can move the VAUS with either the buttons or the dial input.  In Ikari, you can use either the mouse (dial) or buttons for rotation.  I imagine Beatmania is similar, although I haven't looked at it in MAME and have no idea how the actual arcade game works.
Tiger-Heli
    • Tiger-Heli
Re:Control FE with Spinner CP?
« Reply #16 on: June 10, 2004, 07:20:34 am »
Depends how your frontend works and to some extent how your spinner is hooked up - If your frontend allows you to use a mouse to scroll vertically, then a spinner hooked to the Y-Axis will work.  However, you might have to re-configure MAME since games like arkanoid are probably set to use an X-axis spinner.
In addition, if your frontend doesn't allow re-mapping of it's input buttons (or if you have different buttons selected for your main panel), you might have to load one codeset in your encoder for front-end use, and then swap this with a different codeset when MAME loads, and then back when MAME exits.  Lots of work, but possible.
« Reply #17 on: June 10, 2004, 07:24:22 am »
Speaking for MAMEWAH: it doesn't support PC joysticks, or mouse devices atm.  And no, emulators can not be merged into one list :(  Both are on my todo list - PC joystick & mouse support is high on my priorities (I am making my analog stick/spinner/trackball panel atm), but merging of emulators is not, since it requires a lot of core re-writing  :P
So from what you've said you might be better off with a different FE - I'm sure Dragon King can do what you want...
rchadd
  • Made in Cornwall
« Reply #18 on: June 10, 2004, 09:39:11 am »
just to clarify: when i say joystick - i mean arcade joystick wired through an IPAC (so that would be basically using the cursor keys).
« Reply #19 on: June 10, 2004, 10:52:28 am »
OK MAMEWAH can handle that ;)
cbmeeks: just thought I would also mention the PC shareware game 'Juno Nemesis Remix' (brought to my attention by the 'good cab games' thread in the Software forum).  The game is basically an update of Tempest, and includes a classic control mode which should be perfect for a spinner - I'll be trying it in a day or 2... :)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #20 on: June 10, 2004, 12:12:28 pm »
Guerilla War
Heavy Barrel
Ikari Warriors
Ok, these could be played with a spinner, but these are mechanical rotory joys, so a spinner will feel akward.  Luckily you can interface the actual rotory joys to a pc :)
One of the reseason controls.dat started :)  In reference to the person who quoted the project, realize that is a short list because there are only 511 games in the system right now.  Please volunteer if you want more :)  Also probably why Minwah posted his list...
In reference to beatmania, dial is a hack for the turn table.  The actual controller did have a mechanism simular to the digital volume control on a stereo receiver.
« Last Edit: June 10, 2004, 12:16:33 pm by SirPoonga »
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #21 on: June 11, 2004, 03:31:35 pm »
Quote from: Tiger-Heli link=board=1;threadid=20283;start=0#msg164059
[quote
You can move it with buttons but not well. The buttons provide a direction but not speed, while the spinner provides both.  You wouldn't be able to move quickly from side to side, which is essential for playing any "Breakout" type game.  It's similar to an anlaog vs. digital joystick.
saint ganked my avatar.
Tiger-Heli
    • Tiger-Heli
« Reply #22 on: June 11, 2004, 03:36:24 pm »
[quote
Right, I was merely trying to point out that MAME also lists buttons for movement in that game, even though the original used an optical spinner (I think) so you can't use MAME's indication of buttons for BeatMania to infer anything about the original game.
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #23 on: June 11, 2004, 05:51:38 pm »
Can PC Stering wheels be used for mame driving games? if so, how? like the ones u see lined up at comp usa by the joysticks and gamepads.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
NoOne=NBA=
« Reply #24 on: June 11, 2004, 06:36:36 pm »
Yes, but only for games supporting a 270 degree wheel.
(Pot based, self-centering, and have directional limiters, like an analog joystick).
Games that require the steering wheel to go all the way around repeatedly need a 360 degree optical wheel.
(Think BIG spinner).
big_garryb
  • Last login:June 09, 2006, 08:08:12 am
« Reply #25 on: June 15, 2004, 07:51:41 pm »
i didnt get a spinner - i assumed my trackball could be used for spinner games......... am i wrong in this??
garry
oh dear - not rain again......Scottish weather is crap, oh well - at least Mame can keep me company.
NoOne=NBA=
« Reply #26 on: June 15, 2004, 08:21:54 pm »
It CAN be used, but I don't RECOMMEND it.
It's really hard to play games like Tempest with a trackball.
It's one of those things where, if you use ONLY a trackball, you'll probably think it's great.
If you ever use a spinner, and then try to go BACK to a trackball, you'll think it's not so great.
big_garryb
« Reply #27 on: June 18, 2004, 07:53:27 am »
i think i will leave a space in the cp.... and maybe get one for future - mostly fighters i play anyway!
cheers for the advice.
garry
« Reply #28 on: June 18, 2004, 11:43:33 am »
I agree...spinners are cool  8)
