Author Topic: Mame32 Vertical and Horizontal Hold/Roll  (Read 1347 times)
chinabox
  • Last login:January 04, 2009, 10:10:05 pm
  • I'm a llama! No, really, I am...
« on: June 08, 2004, 01:52:21 pm »
I'm having some trouble figuring this problem out, as well as some trouble figuring out which forum to post this in :)  Not sure if this is a problem with software, hardware, or my arcade monitor.  Here's the deal:
I'm using an AdvanceMENU, Mame32, JPAC, ArcadeVGA, WG arcade monitor setup.
I have no problem with horizontal games at all, but when I try to play a vertical game (like 1942, for example) I get a slow (very annoying) rolling of the image.  I can alter the monitor "Vert Hold" setting specifically for vertical games, but then I get a roll when using Windows or a Horizontal game.  Am I missing a setting somewhere--in MAME, AdvanceMENU, etc.?
Please lead me in the right direction!
Thanks,
Zach
pacman
  • Last login:October 01, 2007, 09:51:35 am
Re: Mame32 Vertical and Horizontal Hold/Roll
« Reply #1 on: July 25, 2005, 07:04:45 am »
Hi China box
I have exatctly the same problem as you and using the same hardware (except the monitor which is an Hantarex). Did you find the solution to your problem? ??? ???
Thx
« Reply #2 on: July 25, 2005, 08:29:35 am »
You need to find the monitors v-hold 'sweet spot'.  It should be possible to stop the image rolling in all modes, but it can prove difficult (use tiny adjustments at a time).
Also, old monitors can benefit from cleaning the v-hold pot.
