Author Topic: Dual Stereo Speakers Setup Question  (Read 2581 times)
jdfriesen
  • Last login:December 05, 2021, 04:19:07 am
« on: June 08, 2004, 03:23:15 am »
Hello all,
First by way of introduction, I was registerd WAY back on the old boards, but due to not having any space for a cabinet, sort of stopped browsing and posting.  However, I now DO have space.
I've collected just about all the arcade hardware that I need, however, I've got a sound card question.  I'm building a cocktail cabinet, and want to have stereo sound on each end of the cabinet.  So, can anyone recommend a sound card to me that will supply essentially 2 duplicate stereo outputs?
Thanks for your time,
John Friesen
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
Re:Dual Stereo Speakers Setup Question
« Reply #1 on: June 08, 2004, 11:48:30 am »
Just use two sets of matching speakers and a headphone splitter plugged into your soundcard.  Should work just fine that way.
jdfriesen
« Reply #2 on: June 08, 2004, 12:54:54 pm »
Well, don't I feel stupid now, lol.  Sometimes the easiest solutions are the best ones.  Thanks for pointing my brain in the right direction GadgetGeek.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #3 on: June 08, 2004, 04:01:32 pm »
does doing this half the power output of one set of the speakers?
jdfriesen
« Reply #4 on: June 08, 2004, 06:17:19 pm »
I wouldn't think so, as long as your using powered speakers.  Of course, I'm more than willing to be corrected if I'm wrong! ;D
MnMCaputo
  • Last login:January 10, 2014, 05:31:40 pm
  • Built original Monster Arcade
« Reply #5 on: June 09, 2004, 01:43:08 am »
well its really not POWER, the power is not from your sound card, its from the amp of your speakers, its more of signal strenght, yes your signal strength will drop a little, but i'm sure the sensitivity of your amp and voice coil will be able to handle it, just spend the extra 20 cents at radio shack and get the gold plated splitters just in to be safe  :)
Built Monster Arcade, Steampunk MP3 touchscreen jukebox, NES itx conversion
AlanS17
    • AlanS17
« Reply #6 on: June 09, 2004, 06:51:38 pm »
Make sure you get a stereo splitter, though. Some splitters simply split the signal into individual left and right mono channels.
You can tell by the connections. Mono plugs have two contacts and stereo plugs have 3 contacts. Of course, the stereo male plug is visible, but it'll be hard to see whether the 2 female connections are mono or stereo without really good eyes and a flashlight or (hopefully) a good explanation on the package.
Fabricating your own as a last resort shouldn't be difficult, though. Radio Shack sells all the parts you need so do such a thing,
