Author Topic: Quick Mamewah Question  (Read 1767 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: June 06, 2004, 10:30:12 pm »
After moving all my mame roms to a new drive, I had to make some changes to Mamewah... Problem being.. I messed it up.
How do I generate a game list that has the full game title? I tried all the different options but no luck. Am I missing a file or something out of my mame folder?
TalkingOctopus
    • My Arcade
Re:Quick Mamewah Question
« Reply #1 on: June 07, 2004, 12:40:23 am »
I am assuming you are talking about MAME.  Make sure you change the list generation from "ROM folder only" to "Rom Folder vs DAT file" in the menu Emulator Settings -> List Generation Settings -> List Generation Method.
Or you can set "List Generation Method = 2" in emu1.cfg.
I hope this solves your problem.
« Reply #2 on: June 07, 2004, 05:36:58 am »
I would set the List Generation Method to 'ROM Folder vs Listinfo (M.A.M.E.)' - that will save you having to create a DAT file :)
chrisindfw
  • I drank what?
« Reply #3 on: June 07, 2004, 08:38:42 am »
I tried both of those. No luck.
Do I need to create a listinfo file or something. What about the dat file?
THanks
« Reply #4 on: June 07, 2004, 10:31:24 am »
No you don't need to do anything for MAME - just make sure your MAME 'Emulator Executable' and your 'ROM Path' are correct.
You're not using MAME32 are you?
chrisindfw
  • I drank what?
« Reply #5 on: June 07, 2004, 12:30:15 pm »
Nope. Im using dos mame. not 32.
I will try again tonight. I will just start with a fresh mamewah and see if I can get it.
« Reply #6 on: June 07, 2004, 02:51:21 pm »
Try Windows Commandline MAME...DOS MAME should work too, but I haven't tested it for a loooong time ;)
chrisindfw
  • I drank what?
« Reply #7 on: June 07, 2004, 03:14:24 pm »
I'm sorry.. I didnt know there was  "DOS" mame.. I am using the command line mame.
« Reply #8 on: June 07, 2004, 07:38:51 pm »
In that case you probably have the Windows one...check if you use a mame.ini file (Win) or mame.cfg (DOS).
