Author Topic: Which games use this joystick?  (Read 1537 times)
JAZ
  • Last login:August 03, 2013, 12:16:52 pm
« on: June 05, 2004, 01:42:37 am »
Its used by Shadow Warriors (makes throwing enemies easier) but is this the default joystick for any other games? Is it worth having?
« Last Edit: June 05, 2004, 01:44:15 am by JAZ »
DaveMMR
Re:Which games use this joystick?
« Reply #1 on: June 05, 2004, 01:52:05 am »
Ninja Gaiden used those joysticks too.
EDIT: Umm yeah I forgot, that's the same game as Shadow Warriors.
« Last Edit: June 05, 2004, 01:53:02 am by DaveMMR »
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #2 on: June 05, 2004, 07:28:12 am »
Battlezone does as well.  There probably aren't too many that use them if you are looking to save costs/space on your CP.
:) Rotate or die! :)
John
  • Last login:June 07, 2004, 06:03:19 pm
« Reply #3 on: June 05, 2004, 07:35:40 am »
I'm actually going to put 2 of these sticks up for my new 4 players cab.  these sticks will go on the edges and i'll use p360s for the middle 2.
the main reason is the firebutton; this way I can use this stick and one p360 for those tank type games and still have a fire button (assault and vindicator)
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: June 05, 2004, 08:55:54 am »
More accurately, - they can be used for Battlezone.  Battlezone used 2-way sticks with a fire button on the right stick, but the handles were longer, etc.
