Author Topic: Laminate sheets : Where can I get it?  (Read 2646 times)
Xenepp
  • Last login:May 19, 2009, 06:53:48 pm
  • Jeff minter is GOD!!
    • Videotopia.Co.Uk
« on: June 04, 2004, 11:27:31 am »
I have scoured the web and can't believe how little info I've pulled up on this subject! Not even a warm lead!
I was planning on using some on my cab (going with plexi glass for my cp)
Does anyone know of a supplier in the Uk?
 -Joel
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re:Laminate sheets : Where can I get it?
« Reply #1 on: June 04, 2004, 04:30:26 pm »
la la la  ;D
« Last Edit: June 04, 2004, 08:47:07 pm by RayB »
NO MORE!!
gibble
  • Last login:December 14, 2015, 05:40:59 pm
    • CaffeinatedGeek.ca
« Reply #2 on: June 04, 2004, 04:34:31 pm »
Maybe you haven't found any because the correct word is "laminant".
...laminant isn't even a word  ???
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #3 on: June 04, 2004, 04:41:22 pm »
 -Joel
Try searching using brand names like Formica and Wilsonart, you might have more hits. (hopefully those products are available in the UK!)
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #4 on: June 04, 2004, 06:22:25 pm »
Uh... no.
MonitorGuru
« Reply #5 on: June 04, 2004, 06:54:36 pm »
Menards, Home Depot and Lowes all sell sheets of "Formica" (common name for laminate, just like "Sheetrock" is common for gypsum wall-board even though that is a brand name too) .  The brands you will find are typically "Formica" and "Wilson-Art" and "Pioneer".
Usually they will have a few select sheets in stock of common styles, and then have tons of hanging tags of samples of sheets you can order.
Warning: It gets VERY expensive to put formica on your cabinet. Unless you built the cabinet out of a single sheet of plywood (most can't get both sides to fit), then you'll need to buy 2 whole sheets of formica and pay a lot for it, especially if special order.
Plus you'll need contact cement and a router with a trim bit.
Honestly, it's cheaper and just as easy to just buy real oak or birch laminated 3/4" MDF sheets to begin with (appx $32 for a 4x8 sheet at Menards when on sale) and then just buy a $5 can of stain and $7 can of polyurathene and stain and poly it in the color you want, and have real hardwood exterior.  Farily durable, hides simple scratches well.
That's what I used when I built an Atari cabaret replica.  Turned out nice.  I primed and spray painted black the cross-pieces at an additional cost of about $5 in paint.
OSCAR
    • Oscar Controls
« Reply #6 on: June 04, 2004, 07:18:52 pm »
Tell me about it!  I had to special order a sheet of Formica brand Colonial Cherry for a Robo cocktail I'm restoring.  It has a slightly more reddish tint than the original, but the grain pattern is very nearly a dead-on match.  The only local Formica dealer in my area is a kitchen/bath contractor.  It cost me $80 for a single 4' x 8' sheet of that particular pattern, where the more common Formica patterns are usually around $50 or so.
As monitorguru said, it can be a very expensive way to finish a cab.  However, in the case of the Robo cockail, I don't think I really had any other options if I wanted a true-to-original finish.  Besides, the Formica is probably the most durable finish you can put on a cab and it should keep looking good for at least another 20 yrs in a home environment.
Here are a few pics of how it turned out:
http://www.oscarcontrols.com/robotron-ct/cherry01.jpg
http://www.oscarcontrols.com/robotron-ct/cherry02.jpg
http://www.oscarcontrols.com/robotron-ct/cherry03.jpg
RayB
  • There's my post
    • RayB.com
« Reply #7 on: June 04, 2004, 08:45:36 pm »
Damn, I've always heard it called laminant. :-D
I apologize to all, the original poster, and most of all to Dictionary.com for not checking with them first, like I usually do.
NO MORE!!
SirPeale
  • Green Mountain Man
« Reply #8 on: June 04, 2004, 09:56:32 pm »
Damn, I've always heard it called laminant. :D
Well, phonetically, you're correct.
depressd
  • Last login:April 04, 2019, 04:29:33 am
« Reply #9 on: June 05, 2004, 12:06:52 am »
Hey, I went to the wilsonart website. They have a reseller locator. Luckily I had a local cabinet shop. I made a call and asked if they would sell sheets of laminate.  I had to buy 4'x8' sheets.
Good luck
