Author Topic: Happ 19" monitor - no go in Space Duel?  (Read 2520 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: June 04, 2004, 09:56:00 am »
Dude selling some monitors says:
"Happ Controls 19" monitors! These fit most video games made since 1979, except starwars, spaceduel, asteroids and Nintendo products. Please email if you would like to know if this monitor will work."
Why wouldn't it work in a Space Duel game?  Maybe I'm reading it wrong - I just want it to work in a Space Duel *cabinet*... there's no reason I couldn't get one for a Mame cab, right?  The monitor just wouldn't work w/ a Space Duel PCB, eh?
« Last Edit: June 04, 2004, 11:20:57 am by Dougmeister »
whammoed
  • Last login:Today at 12:55:54 am
  • Crack don't smoke itself
    • NiceMite
Re:Happ 19" monitor - no go in Space Duel?
« Reply #1 on: June 04, 2004, 10:21:44 am »
Yes it will work for mame.  He is just saying that it is a raster monitor and it won't work for vector games like space duel.  Has nothing to do with the cabinet itself.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #2 on: June 04, 2004, 10:23:05 am »
Yeah, I think it'd work fine in a Space Duel cab. He must mean that it won't work with vector PCBs.
Edit: SNAP!
« Last Edit: June 04, 2004, 10:24:02 am by JoyMonkey »
Dougmeister
  • Dig-Doug
« Reply #3 on: June 04, 2004, 10:28:39 am »
Cool.  Thanks guys.
Now can you help me out a bit more?  I've read the Monitor FAQ, and from what I can gather, it breaks down like this:
Arcade Monitor
Plus:
+ realistic
+ can rotate it
Minus:
- need ArcadeVGA card ($90)
- or something else (?) to get it to work
Computer Monitor
Plus:
+ easy setup
Minus:
- not very realistic w/out adding scanlines, etc.
- cannot be rotated?
TV Monitor
Plus:
+ may have one just sitting around
Minus:
- Need video card w/ TV Out
Is that about it?
« Last Edit: June 04, 2004, 10:29:12 am by Dougmeister »
Ken Layton
  • Guru
  • Technician
« Reply #4 on: June 04, 2004, 11:15:49 am »
Two problems here:
Number one is the fact that Space Duel is an X-Y (vector) game not a raster game.
Number two is the fact that X-Y monitors had a picture tube that was shorter in depth. Some color raster monitors will not physically fit in this cabinet because the tube is longer and would stick out the back of the cabinet and get busted. Better check the physical specs closely of the monitor you want to use or you might be throwing your money away.
Dougmeister
  • Dig-Doug
« Reply #5 on: June 04, 2004, 11:22:25 am »
Ok.  Hmmm.
So for a newbie such as me, as far as difficulty/complexity goes, arcade monitors are the trickiest to get set up correctly?
Then would come television monitors, then computer monitors (easiest), right?
android
  • Last login:August 21, 2006, 09:44:47 am
« Reply #6 on: June 04, 2004, 12:30:40 pm »
Two problems here:
... when used with the original PCB. In otherwords, in an original Space Duel cabinet you wouldn't be able replace the original monitor  with a Happ one because the original Space Duel circuitry won't be able to handle it. But, obviously, if you connect a Happ monitor to a PC with Mame, then you should be able to play any emulated vector games with no problem. If you use andy warne's Arcade VGA card, it should make it easier to do this kind of setup.
-- Android
Dougmeister
  • Dig-Doug
« Reply #7 on: June 04, 2004, 01:18:27 pm »
So what benefit is there in buying an arcade monitor ($100+) and an ArcadeVGA card ($90) when I can pick up a 20" TV for $100 and a cheap, decent video card w/ TV out for $20?
Chris
    • Chris's MAME Cabinet
« Reply #8 on: June 04, 2004, 02:46:17 pm »
Also remember that arcade monitors are open frame, so you're exposed to high-voltage components.  If electricity makes you nervous, this may be an issue.
--Chris
--Chris
Dougmeister
  • Dig-Doug
« Reply #9 on: June 04, 2004, 02:53:49 pm »
What's the difference between an arcade monitor and a television with the case removed then?  More than I realize, I guess.
(I realize they are set to operate @ dif't frequencies, no tuner in arcade monitor, etc.)
SirPeale
  • Green Mountain Man
« Reply #10 on: June 04, 2004, 08:15:52 pm »
Because you don't need an ArcadeVGA unless you're running Windows, and even then there's the far less expensive Trident Blade T-64.
It's all about picture quality.  I've seen it all, and I would go with an arcade monitor setup any day.  Next would be computer monitor.
