Author Topic: pinball table coin doors?  (Read 685 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: June 02, 2004, 05:40:13 pm »
What is the difference between a regular coin door and a coin door from pinball table?
would a pinball table door be good alternative to be used in a cocktail cab?
do they accept the same coin mechs?
Ken Layton
  • Guru
  • Technician
Re:pinball table coin doors?
« Reply #1 on: June 02, 2004, 06:04:08 pm »
Pinball doors are only made in the wide format not the tall skinny format found on over/under video game doors. The pinball door has test/volume/bookeeping switch assembly and wiring harness attached. Generally speaking all coin mechs should interchange between over/under doors and pinball doors that are made after 1996 (A.M.O.A. compliant).
