Author Topic: $$ Waiting for someone to hookup my Arcade Monitor  (Read 13670 times)
Bobby115
  • Last login:July 18, 2011, 06:55:13 pm
« on: May 30, 2004, 10:39:07 pm »
I have $$ Waiting for someone to hookup my Arcade Monitor to my PC. It's an arcade monitor and will need to be hooked up to an Arcade VGA I have. I REFUSE :-) to touch the monitor LOL...........
I'm in Long Island NY and would like to get it done as soon as possible
Please E-MAIL me (Bobby115@aol.com) or post here...
Thanks in advance.....
Here is the monitor I have : Zenith Model - 25K7131 - Wells Gardner - 120 Volt - 60 HZ - 100 MAX
SirPeale
  • Green Mountain Man
Re:$$ Waiting for someone to hookup my Arcade Monitor
« Reply #1 on: May 31, 2004, 08:08:01 am »
Too bad I'm not closer.  I like $$.
Bobby115
« Reply #2 on: May 31, 2004, 09:16:47 am »
I WISH YOU WERE CLOSER :-)
I'm dying to get this done :-) LOL
Anyone??
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #3 on: May 31, 2004, 10:38:49 am »
Damm I would have done it for free.
Curls in the squat rack !?!?!
SirPeale
« Reply #4 on: May 31, 2004, 10:40:13 am »
It's not terribly hard.  Mains power to iso transformer, which then goes to the monitor.  Are you using a J-PAC?  If so, that's the hard part, and you're done.
Bobby115
« Reply #5 on: May 31, 2004, 11:11:20 am »
Thanks guys.............
Its gonna be hooked up to an Arcade VGA............I think I needed to cut wires from the monitor somewhere and connect it to the special cable that comes with the Arcade VGA card.
As you can see I'm really not interested in doing this myself..........LOL....I have a wife and kids....!!! HAHA
Dont wanna kill myself :-)
SirPeale
« Reply #6 on: May 31, 2004, 11:32:45 am »
You shouldn't have to cut any wires.  There should be a harness with RGB and sync.  That's what you hook up to your hard, and if you're not using a J-PAC, you will have to hack a VGA cable to attach it.
You may need a video amp as well.
Bobby115
« Reply #7 on: May 31, 2004, 01:04:00 pm »
Here is the card and the cable I need to hookup......The monitor has everything....It It powers on and everything.......I have a board connected to it and everything comes up :-)
Thanks guys
SirPeale
« Reply #8 on: May 31, 2004, 01:07:01 pm »
Looks like the cable is pre-stripped. You'll need to connect those ends to the harness on the monitor.  Match each color, and sync, and off you go.
Bobby115
« Reply #9 on: May 31, 2004, 01:45:13 pm »
From the picture above can you locate those wires or do I need more photo's................
(Where are all the GREAT Arcade TECHS in NY that want to come to my HOUSE !!)
LOL
« Last Edit: May 31, 2004, 01:45:34 pm by Bobby115 »
Rocky
« Reply #10 on: May 31, 2004, 02:40:05 pm »
The colors are usually:
Red - Red
Green - Green
Blue - Blue
White - Sync
Black - Ground
There isn't enough voltage going through those to hurt you. You can touch them when the monitor is on and not get a shock.
Actually, moving and touching the monitor is more dangourous than hooking the signal to it.
Bobby115
« Reply #11 on: May 31, 2004, 05:37:31 pm »
Can you see the wires in this Photo???
Where are the guys that wanna make some cash? haha
SirPeale
« Reply #12 on: May 31, 2004, 08:05:40 pm »
The group of wires on the right, that's wht gets hooked up to data feed.  The other on the left looks like power.
Bobby115
« Reply #13 on: June 01, 2004, 11:18:51 am »
I will take some more photo's tonight to try to and make sure I get the right wires.......
BUT IN THE MEANTIME IF SOMEONE wants to make some MONEY, please E-MAIL me at bobby15@aol.com
Hey Peale , you should move to long island LOL
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #14 on: June 01, 2004, 11:32:37 am »
Quit being a sissy and do it yourself!  That is why part of the name here is "build your own."  Not "beg for someone else to do it because you are scared of it for no rational reason."  :)
That monitor probably has NO charge in it, not to mention that you are not going to do anything that will hurt you.  Read the specs on the monitor and follow the instructions with the ArcadeVGA cable.  Disconnect the header from the monitor board before you start and you will be fine. Get some heat-shrink tubing and splice those wires together.  Call WG and order a power cord.
You are NOT going to hurt yourself.
Coleman
Bobby115
« Reply #15 on: June 01, 2004, 11:49:55 am »
LOL......OK Coleman
iwillfearnoevil
  • Last login:February 13, 2010, 07:08:43 pm
« Reply #16 on: June 01, 2004, 01:09:18 pm »
make sure you do this after the kids are bed to spare them running in after hearing a loud zap in the next room over and seeing you laid out on the floor.
Bobby115
« Reply #17 on: June 01, 2004, 01:27:10 pm »
Go ahead.......Make it harder....!! LOL
Hoagie_one
  • Um....whats a cabinet
« Reply #18 on: June 01, 2004, 03:54:46 pm »
you could just wear rubber gloves
MnMCaputo
  • Last login:January 10, 2014, 05:31:40 pm
  • Built original Monster Arcade
« Reply #19 on: June 02, 2004, 12:49:17 am »
LOL, I could just see him all dressed up in this suit.
http://www.wolfhazmat.de/hazmat_sunghan4.htm
ps, just make sure you follow the monitor section on byoac and you'll be just fine  :)
Built Monster Arcade, Steampunk MP3 touchscreen jukebox, NES itx conversion
Bobby115
« Reply #20 on: June 02, 2004, 07:32:13 am »
Is this were you come for help or no??  ;D
Buddabing
« Reply #21 on: June 02, 2004, 09:45:12 am »
There is no need to discharge the monitor.
What do the wires hanging off the right edge of the picture connect to?
I have an ArcadeVGA card and the breakout cable, just like you have. My arcade monitor had a plug similar to what you have, except the wires all ended in a stripped end of bare wire.
All I had to do was connect red to red, green to green, blue to blue, ground to ground, and I was golden. The only tricky part was connecting the sync wires, that just took trial and error. Just twist the wires together and make sure the connection is secure when everything works (either solder+electrical tape or one of those screw-on cone-shaped connector thingies)
It's not rocket science. The hardest part of the project was lugging that heavy arcade monitor upstairs.
Please read the wiki!
iwillfearnoevil
« Reply #22 on: June 03, 2004, 01:32:12 pm »
bobby hasn't posted today ... i hope he's okay   ;)
fredster
  • It's all good!
« Reply #23 on: June 03, 2004, 02:06:31 pm »
He's better off. I'm really surprised he got this far. Must be an accountant.
Bobby115
« Reply #24 on: June 06, 2004, 11:11:10 pm »
I'm still here. Didn't get a chance to do it yet.........NOT DEAD !
I will probably give it a shot tomorrow night.
You would think asking for some help wouldn't get so many negative responses...
Cisco Kid
« Reply #25 on: June 07, 2004, 08:05:13 am »
... to be expected ... some people just don't have any manners  ;D
menace
« Reply #26 on: June 07, 2004, 08:33:14 am »
I think most folks are just giving you a good natured hard time --so quit being a wimp and wire it up already  ;D ;D ;)
Bobby115
« Reply #27 on: June 07, 2004, 01:21:21 pm »
I'm looking to get to it tonight :-)
Then the Cab will be completed.
Bobby115
« Reply #28 on: June 07, 2004, 09:59:02 pm »
Hey Guys, Quick question......I was speaking to someone on the boards who is helping me out and this is the message he gave me :
~~~This might be a JAMMA connector. If that
Bobby115
« Reply #29 on: June 07, 2004, 09:59:27 pm »
Bobby115
« Reply #30 on: June 07, 2004, 09:59:50 pm »
JoeB
  • Last login:September 18, 2025, 12:42:30 pm
  • NES Fanatic
« Reply #31 on: June 07, 2004, 10:26:01 pm »
Bobby..
I strongly suggest you get a pro to do the hookup for you.  The monitor will require a new power supply as well.
You have an arcade PCB hooked there and a single power supply feeding both monitor & Jamma board.
If you remove the Jamma board and replace with PC, the power supply will no longer have the 5V, 3V, etc. loads (it will just have the 110V monitor load) which will result in it burning out.
You need to remove the power supply and Jamma board.. and build a new power supply for the monitor as outlined here:
http://www.dameon.net/BBBB/buildit.html
Cisco Kid
« Reply #32 on: June 07, 2004, 10:30:18 pm »
The looks like a JAMMA game.
Now you got me curious .... what cabinet is that your converting? (I've never seen that particular arcade board before.
BTW ... that power supply isn't feeding the monitor anything  ;D ( ... it's getting it's power from the wall outlet (120V) .... then it goes through the isolation transformer (the big thing next to the power supply) since it's an older monitor and doesn't have one built into it and then that goes to the monitor).
The power supply supplies your +12V, +5V, -5V, and a good ol' GND. ( ... and on occassion (newer boards) ... then a +3.3V  ;) )
« Last Edit: June 07, 2004, 10:42:39 pm by Cisco Kid »
MrArcade
  • Last login:May 29, 2025, 02:06:06 pm
  • I wish I had time to play these games !!!
« Reply #33 on: June 07, 2004, 10:34:43 pm »
You need the plug in this picture
the standard is :
from the bottom of the picture up:
large plug
Red, Green, Blue, Ground, +vert sync, +horiz sync, blank(key),
small plug
ground, -vert sync, -horiz sync
Odds are you need to hook:
from arcadevga harness to plug in picture
red to red
green to green
blue to blue
all grounds to ground
nothing to + vert sync
both sync wires to + horiz sync
That works on most monitors
there is a picture on the right inner side of the chassis that will show what the pins on that plug are.  the above first four connections are standard...re-red, green-green, blue-blue, all gnd-gnd the only odd one is the sync wires ...some monitors want both to + h sync, some to + v sync, some to - h sync, some to - v sync, and some want them hooked up individually.  Hook the colors and ground up first, then first try both sync from arcadevga twisted and try each sync wire on the monitor...one should work
Oh, the memories of living on pizza subs and Dr Pepper...
MrArcade
« Reply #34 on: June 07, 2004, 10:38:15 pm »
Bobby..
ummm...no
you can just pull the jamma board.  the monitor just wants the 110v coming through the isolation transformer.  you can just leave the power supply and isolation transformer in there.  the 110v does have to go through the isolation transformer...which I wager it already is.
SirPeale
« Reply #35 on: June 07, 2004, 10:41:05 pm »
Monitors don't take a power supply.  There is an isolation transformer right there in the second pic, on the bottom right.
Actually, if there's no load on the power supply, some of them don't turn on at all.  Certainly shouldn't burn it out.
The power going to the power supply (which powers *just* the PCB, NOT the monitor) should be on a separate loop from the monitor altogether.
This was edit for a Mame cabinet, but the concept is still the same.
MrArcade
« Reply #36 on: June 07, 2004, 10:41:34 pm »
in this picture:
the board on the left has the power supply and the isolation transformer on it.  it is ok as is...or you can eliminate the power supply...it is the grey box on top.  If you really want to eliminate it let me know and I can tell you what to do
Bobby115
« Reply #37 on: June 07, 2004, 10:44:48 pm »
It was made by Leyland
and its was called World Soccer Finals
Cisco Kid
« Reply #38 on: June 07, 2004, 10:45:54 pm »
I'll help you get rid of that board if you want ... hehe  ;)
Bobby115
« Reply #39 on: June 07, 2004, 10:47:32 pm »
I don't mind keeping the power supply and the isolation transformer ......Don't matter to me
