Author Topic: Best Trackball and Spinner games?  (Read 14021 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: May 29, 2004, 01:23:37 am »
I realize there is already a topic for the all-around best games, but what about trackball and spinner games specifically?
I've purchased a Happs 3" trackball and an Oscar's Controls Vortex Spinner, but I haven't really played many trackball or spinner games.  The only ones that come to mind are Golden Tee Golf II (trackball) and Arkanoid (spinner).
What are some other good (...great?) trackball and spinner games?
Apollo
    • Eight Bells
Re:Best Trackball and Spinner games?
« Reply #1 on: May 29, 2004, 03:03:30 am »
Well I would say the majority of people on this forum install a spinner to play either Tron or Tempest so that's a good start. Also driving games can use spinner instead of wheel ( mostly ).
Trackball=Missile Command, Centipede, Marble Madness, Crystal Castles etc.
Richy
  • Last login:September 15, 2004, 09:04:53 am
« Reply #2 on: May 29, 2004, 05:55:50 am »
For Trackball
The Irritating Maze
Rampart
Shuuz
Any bowling game
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #3 on: May 29, 2004, 06:02:01 am »
I like Puzz Loop, although it's a pain to play with a joystick since I haven't installed a spinner..YET.
PaulG
  • Last login:April 10, 2007, 03:25:56 pm
« Reply #4 on: May 29, 2004, 08:02:14 am »
And I'll be the 1st to mention Cameltry.  A DEFINITE must for the spinner.
DaveMMR
« Reply #5 on: May 29, 2004, 08:42:25 am »
CABAL was a game I always found amusing.  And that's another game that used 2 trackballs (well if you want two players simultaneous anyhow).  Also the Atari Classics (I don't know if I have the name right - it was unreleased and has an update to Centipede and Missle Command) allows two players at the same time.
pocketbikez
  • Last login:January 16, 2005, 06:23:36 pm
  • INSERT COINS
    • my arcade cabinets
« Reply #6 on: May 29, 2004, 09:26:14 am »
I like the the new game ARGUS, where you're a trackball controlled superhero.
another good trackball game is QUANTUM.
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« Reply #7 on: May 29, 2004, 09:56:53 am »
Gotta give another vote for Cameltry, which I never even heard of before this group and building my CP.  Really fun.
I tried the Irritating Maze and found it to be, well, as advertised.  Interesting, but for whatever reason I'm terrible at it.
Tempest is the #1 spinner game of all time, imho.  And actually I'm finding that many shooters work pretty well with a trackball--certainly not to the level of guns, but I finished Area51 with a trackball and did moderately well.
-->VPutz
Chris
    • Chris's MAME Cabinet
« Reply #8 on: May 29, 2004, 10:35:54 am »
Shuffleshot.  I also use my trackball to play Star Wars and Tail Gunner since I don't have a yoke.
Any 360 degree driving game is a candidate for the spinner.
--Chris
sofakng
« Reply #9 on: May 29, 2004, 11:02:40 am »
Thanks for all the great suggestions!  Keep them coming!
So far I've only really played Missile Command, Golden Tee Golf II, and Centipede.  They all work great with MAME32 and my Golden Tee trackball (Happs 3") and my Opti-PAC.
However Marble Madness does not respond well *at all* to the trackball.  I have to swing the trackball a TON and the marble barely even moves.  I've tried tweaking my settings from instead the game (Analog Controls menu) but it doesn't seem to help very much.
Anybody have any suggestions?
whammoed
  • Last login:December 18, 2025, 10:30:53 am
  • Crack don't smoke itself
    • NiceMite
« Reply #10 on: May 29, 2004, 11:18:31 am »
From what I remember that's the way marble madness is...you really have to spin and spin and spin to get that little sucker going.
Chris
« Reply #11 on: May 29, 2004, 11:49:31 am »
You can't fling the ball around in Marble Madness.  However, you should be able to just get the marble moving fast enough to jump from the track on the starting race to one of the side platforms (although it's hard).  If you have it over-sensitrive, you'll get backspin.
Don't forget that your Windows mouse settings and driver have an impact here as well.
--Chris
--Chris
Chris
« Reply #12 on: May 29, 2004, 12:10:25 pm »
I just checked mine.  For my 3" Happ trackball, I have the sensitivity at 50% and I can jump on the first level.  At 30% I can't.
--Chris
--Chris
sofakng
« Reply #13 on: May 29, 2004, 12:42:06 pm »
What are your Windows mouse settings?
I'm using an Opti-Pac with the default USB driver (in case that matters).
Chris
« Reply #14 on: May 29, 2004, 12:54:52 pm »
I'm using a mouse hack with a Microsoft IntelliMouse driver.  Remember that an arcade ball is very low-resolution as mice go, so kick the mouse speed to maximum and accelleration to none.
Here's a good test: Do you have Camel Try installed?  Put Camel Try in service mode; one of the tests will tell you how fast you're spinning the trackball.  Start spinning slowly and work your way up through spinning as fast as you can.  You should progress from "Very Slow" to "Very Fast". If you get to "Very Fast" quickly and it drops off, you're getting backspin; if it never makes it to "Very Fast" something's not sensitive enough.
« Last Edit: May 29, 2004, 12:55:24 pm by Chris »
--Chris
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #15 on: May 30, 2004, 06:22:12 am »
A great spinner game, one I never heard of before I started poking around the 1000's of games in Mame, is Tac/Scan.  If you have a decent sound system, turn the sound up on this one, turn the lights out in your arcade room and enjoy the experience.  One of the coolest sound experiences this side of Defender.
Here is the KLOV listing of Tac/Scan
http://www.klov.com/game_detail.php?letter=T&game_id=10007
:) Rotate or die! :)
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
« Reply #16 on: May 30, 2004, 12:06:33 pm »
I also have the 3" Happs trackball and Vortex spinner.
The trackball games I play the most are -
Millipede, World Class Bowling, Shuffleshot and Missile Command.
The spinner games I play the most are -
Tempest, 720 Degrees, Super Sprint, Pole Position and Arkanoid.
NoOne=NBA=
« Reply #17 on: May 30, 2004, 03:22:02 pm »
Three of my favorite spinner games are Star Trek. Blasteroids and Omega Race.
Larry Smith
  • Last login:September 01, 2004, 07:27:11 am
« Reply #18 on: May 31, 2004, 09:48:37 pm »
Best trackball game: Missle Command
Best spinner game (best game ever?): Tempest
Dave Theurer Rules!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #19 on: May 31, 2004, 11:37:10 pm »
I want three tballs at some point or a dedicated machine of the obvious 3 tball game :)
