Author Topic: EZ way to put on t-molding??  (Read 2353 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: May 27, 2004, 10:35:48 pm »
Hi
I got my tmolding for my control panel today. the panel is done and looks good, I am satisfied with it. I do not want try and cut the tmolding slot and screw it up.. any advise on how to do it right? I only have one shot.. its 3/4" inch black tmolding.
thanks
JIM
SirPeale
  • Green Mountain Man
Re:EZ way to put on t-molding??
« Reply #1 on: May 27, 2004, 10:41:42 pm »
Get some scrap board and practice cutting first!
spystyle
« Reply #2 on: May 27, 2004, 11:36:00 pm »
« Last Edit: December 09, 2006, 12:10:04 pm by spystyle »
Demon-Seed
« Reply #3 on: May 28, 2004, 09:49:51 am »
Hi
I seen that picture of the router you have...hmm its round and sits ontop of the wood.. the router I have is a handheld one...actually used to cut electrical outlets in try wall.. hmmm.... it can't use the top of the wood as a guide like the one in your pic :( any other solutions?? All I have is the control panel to t-mold
thx
JIM
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #4 on: May 28, 2004, 10:39:18 am »
Sounds like you have a handheld dremel type thing?  I doubt you would be able to cut a t-molding slot very well with that at all.  A normal router/router bit is self guiding, so it really does most of the work for you.  You can route a slot around the entire panel in seconds.  With a handheld dremel device I don't see how you could do it.  Got any friends that you could borrow a router from?
:) Rotate or die! :)
SirPeale
« Reply #5 on: May 28, 2004, 10:41:35 am »
Like I said, get a piece of scrap and practice.
If you don't have scrap, there's got to be a construction site somewhere with a dumpster.
It doesn't even have to be 3/4" (or whatever thickness) since it's just practice.
Demon-Seed
« Reply #6 on: May 28, 2004, 11:10:00 am »
Hey
I know but I was wondering if it is possible without a router? any handheld tool? not sure I can get a router thats why :(
AlanS17
    • AlanS17
« Reply #7 on: May 28, 2004, 11:46:32 am »
Most Home Depots rent tools... and you'll only need it for a day anyways...
unclet
« Reply #8 on: May 28, 2004, 12:12:53 pm »
I called local cabinet makers and found one which had a 1/16" router bit for T-molding.   He charged me $10 to cut both sides of my cabinet along with the 4-player control panel.   That is the easiest way I found since I really dont like routers ...... plus it is cheaper than renting one as well.
Remember these are professional cabinet makers so the chances they "mess-up" is a lot less than if I tried it myself.... good luck!
spystyle
« Reply #9 on: May 28, 2004, 04:57:44 pm »
I've worked in construction and often seen those being used to make freehand cuts in drywall and sheetrock for electrical outlets, it's probably called a RotoZip or DeWalt Drywall Cutter. That's not the ticket for routing a slot for the t-molding.
Dig it?
Craig
Hi
thx
JIM
Demon-Seed
« Reply #10 on: May 29, 2004, 06:29:35 am »
ok i will look into it.. my bro may have one
