Author Topic: trackball Imperial  (Read 876 times)
blue
  • Last login:September 07, 2006, 12:41:40 pm
  • up,up,down,down,left,right,left,right BABA ...
trackball Imperial
« on: May 27, 2004, 01:39:25 pm »
Does anyone have one of these:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=187&item=8108049087&rd=1
Do they work well?
It should still work if i use a PS/2 - USB adapt. right?
Any help on this would be great.
Thanks.
*EDIT:
Sorry if this is redundant ... the search isn't working for me right now
« Last Edit: May 27, 2004, 01:40:32 pm by blue »
Goz
  • KOTA
Re:trackball Imperial
« Reply #1 on: May 27, 2004, 01:48:41 pm »
If you get one of these, I'd suggest getting the booster kit from Groovy Game Gear http://www.groovygamegear.com/cgi/surfshop/shop.cgi?ud=U0tHMFFJRDdMWSUlJSUlJTEwODU2Nzk5MTIA&storeid=1&cols=1&categories=0025&&c=detail.htm&itemid=TBOOSTIMP3
This is basically a replacement set of encoder wheels. The ones that come in the TB are plastic and the kit are precision metal. This enhancement improves the performance of the TB.
And yeah you can use a USB adapter with it.
Hope it helps,
-Goz
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #2 on: May 27, 2004, 01:56:35 pm »
These trackballs are great.  I've had zero problem with accuracy or durability with them straight out of the box.  You may want to get it in-hand and drive it for a while before deciding whether to "upgrade" the parts.
Stingray
« Reply #3 on: May 27, 2004, 02:24:19 pm »
I have one. It's a fantastic trackball. Mine seems to work perfectly with the stock encoder wheels.
-S
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #4 on: May 27, 2004, 02:24:53 pm »
I have bought two of them.
They work great and I have had no problems with the encoder wheels at all.
I use them in PS/2 mode.
The two I bought did come with thin washers btween the top and bottom halves.  Their was a lot of play in the ball, it could lift up off the rollers a little bit depending on how you hit them, I rmoved the washers and that took care of the looseness.
American Laser Games Wrapper
O2em Rom Utility
paigeoliver
  • Awesome face!
« Reply #5 on: May 27, 2004, 06:16:15 pm »
I have one. I THOUGHT it was fine with the stock encoder wheels, but then I ordered the upgrade wheels from groovygamegear on a lark (I was making a huge order, and I saw those staring at me, and got them). It made a huge difference.
Basically the Imperial ball is smoother rolling than the Happ ball, but it doesn't have that giant roll time that the happ balls have. With the upgraded encoders it STILL doesn't have the giant roll time, but now a good roll with have the same basic effect, while maintaining that smoothness.
Basically, with the upgraded encoder wheels it is a better ball than the Happ/Atari midi trackball.
