Author Topic: MameWah changes my resolution?.?...  (Read 2223 times)
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
« on: May 26, 2004, 12:02:03 pm »
Often (not all the time) when I exit to windows from Mamewah my desktop resolution has been changed from 1600x1200 to 800x600.  Any ideas why and how to stop it?
Also will MameWah support a 1600x1200 layout if I create one?
-G
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
Rocky
Re:MameWah changes my resolution?.?...
« Reply #1 on: May 26, 2004, 03:17:38 pm »
The only time Mamewah doesn't return my desktop to its original size is when it exits because of an error. However, I have not tried the newest version (.97?) yet.
Rocky
AGGIEZ
  • Last login:January 30, 2017, 05:59:50 pm
« Reply #2 on: May 26, 2004, 03:58:11 pm »
-G
I just got MAMEWAH up and running on my PC today and have been playing alot of the fighters on my keyboard. I have been having this same problem! I'm also getting errors when I hit the Shift key too much. Another problem is when I hit the CTRL and ALT buttons at the same time I'm pressing a directional button. It flips the screen. ????
simplygriff
    • simplygriff.com
« Reply #3 on: May 26, 2004, 04:25:04 pm »
Rocky
Now that you mention it it is usually when I do something stupid like hit the windows key or shift too many times and turn on sticky keys.  I think things will be fine when I start using my joystick all the time.
-G
www.simplygriff.com
« Reply #4 on: May 26, 2004, 07:41:09 pm »
-G
Some apps can steal focus from MAMEWAH too - check it isn't that.
Turn the annoyance that is Stickykeys off too - Shift is a standard MAME button so could still give you jip with sticks/buttons...
And MAMEWAH will work with any resolution, as long as your video card can successfully change to that res...
AGGIEZ
« Reply #5 on: May 26, 2004, 08:24:45 pm »
-G
How do you turn off Stickykeys??
« Reply #6 on: May 27, 2004, 07:24:56 am »
Control Panel > Accessiblilty Options
Untick 'Use StickyKeys', click on Settings and untick 'Use shortcut'.
simplygriff
    • simplygriff.com
« Reply #7 on: May 27, 2004, 10:18:25 am »
I haven't had any more problems with it since I turned off sticky keys and am more careful about hitting that windows key.
And I got it running at 1600x1200 with no problems last night.  Even dabbled with the layout designer.  Pretty neat stuff.
-G
www.simplygriff.com
