Author Topic: Minipac / Pause Button question...  (Read 1162 times)
timsatari
  • Last login:August 31, 2020, 05:52:07 am
  • By the power of Greyskull!
« on: May 19, 2004, 05:47:32 pm »
Hmm, well I set up a button on the side of the cabinet to 'pause' mame using the 'P' button (i programmed it in). It pauses OK, but I cannot unpause the game...the button is a very simple press down (non-clicky) type...any tips here as to why it doesn't seem to work? I can upause the game again using p on the keyboard..
thanks!
tim
Witchboard
Re:Minipac / Pause Button question...
« Reply #1 on: May 19, 2004, 06:41:40 pm »
Does it have a momentary switch?
timsatari
« Reply #2 on: May 19, 2004, 08:12:49 pm »
I'm not sure what a momentary switch is...but this switch simply depresses and touches a plate - it doesn't make a click sound at all if that helps...
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #3 on: May 19, 2004, 08:19:03 pm »
Sounds like your button keeps the contact closed.  What Witchboard meant by "momentary switch" was "does the switch open when you stop pushing it."  A standard pushbutton has a momentary switch.  A lightswitch in your home is not a momentary switch.
If the switch stays closed when you stop pushing it, you should use a different switch.  MAME expects one push to pause and one push to play.
Coleman
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #4 on: May 19, 2004, 11:08:31 pm »
To kind of expand on what jcoleman said, I have this on my site:
Maintained switch:
When you click it on it STAYS on, when you click it off it STAYS off. Think of a regular wall-mount light switch in most homes - when you turn it on by flicking the switch, the switch physically stays in the "on" position until you flick it back off.
Momentary switch:
There is no "on" or "off" position. You push it in, it send its signal, and it pops right back out when you let go of it. An easy example would be your television remote control: you push the same "power" button to turn your TV on and off, but you can't physically look at the switch and tell if it's on or off. The switch doesn't stay in while it's on and pop out when it's off. It sends its signal while the button is held down, and stops sending its signal when you let go of the button.
