Author Topic: Wells Gardner - Monitor Upgrade  (Read 2032 times)
Bobby115
  • Last login:July 18, 2011, 06:55:13 pm
« on: May 17, 2004, 09:44:50 am »
Right now I have a monitor installed in my cabinet
Zenith Model - 25K7131 - Wells Gardner
120 Volt - 60 HZ - 100 MAX
and I want to replace it with a D9200 - Wells Garder
is there a place I can get the spects (Measurements of the two to see if thing thing can fit in my cabinet correctly??)
Thanks in advance for the help
Bobby
Bobby115@aol.com
menace
Re:Wells Gardner - Monitor Upgrade
« Reply #1 on: May 17, 2004, 10:11:31 am »
I'm guessing you've been to wells gardner site?
http://www.wellsgardner.com/wellsgardner31/supportdata/27%20inch%20D9200%20black%20&%20white.pdf
and mike's arcade (although it might not be the 25"--i forget)
http://www.mikesarcade.com/arcade/monitors.html
Ken Layton
  • Guru
  • Technician
« Reply #2 on: May 17, 2004, 10:14:49 am »
Yes, contact Wells-Gardner (www.wellsgardner.com) for the specs. I believe most specs are on the website. Remember though that what you have now is a 25" monitor and the smallest D9200 is a 27". Also the D9200 is very expensive not only to buy but to ship because of the added weight.
