Author Topic: CPU usage: USB ethernet vs onboard ethernet  (Read 1131 times)
krick
  • Gotta have blue hair.
« on: May 17, 2004, 01:55:37 am »
My mame machine is using a motherboard with an onboard ethernet port.  I wanted to connect my machine to my network via a wireless connection.
However since wireless ethernet bridges are still about $80, so I bought a wireless adapter that that plugs into a USB port (D-Link DWL-122, $40).
I've recently been thinking about how much CPU time this thing might be using, even when it's idle and not transferring data.  Or since it's a windows machine, it might be downloading windows updates in the background or something.
I've also wondered about sharing the USB connection with other USB devices (trackballs, mice, spinners, lightguns, etc...).  The motherboard only supports USB 1.1.  Is there any danger of performance problems because of the USB wireless adapter hogging the connection?
Has anybody put any thought and/or research into this?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
Re:CPU usage: USB ethernet vs onboard ethernet
« Reply #1 on: May 17, 2004, 11:07:58 am »
Why don't you just disable it when you aren't useing it.
krick
« Reply #2 on: May 17, 2004, 11:15:56 am »
I could do that.  I was just wondering if anybody had what might happen if I didn't.
Hantarex Polo 15KHz
Tilzs
  • Neat
    • Cocktail Arcade
« Reply #3 on: May 17, 2004, 12:28:09 pm »
As long as they have an idependent host controller for each port (which they should) then you shouldn't have any problem. If you hub out a connection then you may run into bandwith. TBH, I wouldn't worry about it but if you are just disable it when not in use
BASSOFeeSH
  • Last login:May 29, 2009, 12:46:42 am
  • TD-2779
    • Trooper Armor
« Reply #4 on: May 18, 2004, 02:05:03 pm »
Also, if you don't want it to run windows update simply disable autoupdate. (hit <windows> + <break>) to bring up the system menu.
PaulG
  • Last login:April 10, 2007, 03:25:56 pm
« Reply #5 on: May 19, 2004, 08:48:09 am »
Just hit Control-Alt-Delete.  This will tell you your CPU usage and whether it's causing overhead.   And a network adaptor and couple mouse peripherals aren't gonna gridlock USB 1.1.
